360cid NOS motor question
#1329250
10/31/12 06:35 PM
10/31/12 06:35 PM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
Hey guys
Is it possible to use small amount of NOS ( around 150hp shot ) with motor with specs like this:
Stock,mild ported heads with stock valves Edelbrock Performer intake Probe forged pistons Stock rods Stock crank Cometic head gaskets CompCams 20-223-3 ( 224/230@.050 ) camshaft About 9,5 compression ratio Petronix Flame Thrower billet distributor QuickFuel SS series 650cfm carb
And what you think is that kind of motor capable for around 300hp power as naturally aspirated?
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
Re: 360cid NOS motor question
[Re: RobX4406]
#1329252
10/31/12 06:49 PM
10/31/12 06:49 PM
Georg
Europa, Estonia
what about stock rods? Can they handle it? What would be REV limit? 6000-6500 max?
Premium Performance
[Re: Georg]
#1329255
11/01/12 08:55 AM
11/01/12 08:55 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
if its not built yet..triple check your top ring gap. it may need to be wider for NO2 your piston and ring manufacturer will have specs.. the rest of the motor will handle it without issue. as long as the parts are blueprinted correctly during assembly. ive been hitting mine for 8yrs..wakes the car up real nice...063 n02 here is a video of no2 vrs n/a .. both cars run same et and mph on motor.. this was a .063 no2 pill..fwiw. http://www.youtube.com/watch?v=I1ZoE-WiQhs
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
