Need a single line swinging pick-up #1329103
10/31/12 02:28 PM
10/31/12 02:28 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I can't seem to find a single line swinging oil pick-up without an entire (expensive) kit. Surely they're out there and I've just missed 'em.
So, can you tell me a good source for just the oil pick-up?
Thanks!
Master, again and still
Re: Need a single line swinging pick-up [Re: DaveRS23] #1329104
10/31/12 02:32 PM
10/31/12 02:32 PM
Never heard of a single line swinging pickup for a Mopar V8
Re: Need a single line swinging pick-up [Re: DaveRS23] #1329105
10/31/12 02:40 PM
10/31/12 02:40 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I have capped one of the dual line swinging pickup fittings and chose the oil port on the the Milodon cap that I wanted to use. I have run 7-8,000 rpm with no problem with a single line.
I have done the same with static pickups and have even made my own pickups.
I have used Milodon and Indy components.
Everything seemed to work.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
