Re: Tech on a 2004 Cummins Fan Clutch
[Re: TheBlueBeast]
#1328467
10/30/12 01:31 AM
10/30/12 01:31 AM
Posts: 10,146 A Red State
SNK-EYZ
A Red State
Unless I'm mistaken it will trip a code and turn on the check engine light. I know that they wouldn't pass the Huntsville (electrical) test on the assembly line if it isn't plugged in. When I was the Final line Huntsville repairman on the line I saw way to many of them like that if there was a new operator on the line. They'd forget to plug it in.
[Re: TheBlueBeast]
#1328469
10/30/12 04:14 PM
10/30/12 04:14 PM
SNK-EYZ
A Red State
If it disengages when it's unplugged I'm thinking that the fan clutch may not be the issue. Whatever sensor tells it to be engaged may be.
[Re: TheBlueBeast]
#1328471
10/30/12 06:34 PM
10/30/12 06:34 PM
Posts: 75,072 U.S.S.A.
JohnRR
U.S.S.A.
from what I can gather from the cummins sited it is computer controlled. I was thinking that it was controlled by the temperature sending unit but they say by the computer/ecm. So that will be a female mammal in heat.
But there has to be something that tells the engine controller to engage and disengae , no ?
[Re: SNK-EYZ]
#1328473
11/01/12 04:24 PM
11/01/12 04:24 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have been out of the dealer for a few years now but I remember that setup in one of my books. I just dont remember the exact way it works. The PCM controls it as it uses the coolant sensor reading which it uses for all the systems that need eng temp reading. I cant remember if you unhook it if it will engauge or disengauge ? Course it will set a code. How does he know its staying engauged ? Can he hear it staying on driving it ? I will try to find the info as I have a whole book on the Diesel systems if I can just find it. Ron
[Re: 383man]
#1328474
11/01/12 05:12 PM
11/01/12 05:12 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
The clutch on our 03 CTD went bad. It messed with the TPS and made the truck accelerate on its own. It was a trip...to say the least.
We unplugged the clutch and drove it that way for 2 months without any issues.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
