coil over schock coil spring! #1328423
10/29/12 08:21 PM
10/29/12 08:21 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
One for the book....
How do I choose the right spring rate for my car when swapping to a rear coilover suspension ?
my 67 Barracuda weights 3100 lbs !
What would be my choice ?
Dan
Re: coil over schock coil spring! [Re: Wedgeman] #1328424
10/29/12 08:24 PM
10/29/12 08:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
What do you plan to do with it?? that matters lighter for straight drag than straight street??
Re: coil over schock coil spring! [Re: Wedgeman] #1328425
10/29/12 08:26 PM
10/29/12 08:26 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
drag race or street use? i have mine set up for drag race right now and i'm at 110lbs springs in the rear. I weight in at 3000 with me in it. also if you have adjustable shocks or not.
Re: coil over schock coil spring! [Re: Deepockets] #1328426
10/29/12 08:44 PM
10/29/12 08:44 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Mostly drag but occasional street use...
I'm spotting QA1 single adjustable schocks..
Dan
Re: coil over schock coil spring! [Re: Wedgeman] #1328427
10/30/12 11:28 AM
10/30/12 11:28 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would think 110's no heavier than 130's
Re: coil over schock coil spring! [Re: Dodgem] #1328428
10/30/12 12:01 PM
10/30/12 12:01 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
My drag pak Challenger weighs 3225 and came with 125's.
2011 Drag Pak Challenger
Re: coil over schock coil spring! [Re: rickseeman] #1328429
10/30/12 12:14 PM
10/30/12 12:14 PM
Dyno1 Offline
Dyno1  Offline
I would run 130's. Dyno
Re: coil over schock coil spring! [Re: Dyno1] #1328430
10/30/12 01:48 PM
10/30/12 01:48 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I run 110s and it handled that well even with the car loaded down with all the crap I brought along for drag week
