Cast or Steel Crank? #132821
10/06/08 09:38 AM
10/06/08 09:38 AM
Casselberry, FL
FiveWoods Offline OP
Casselberry, FL
How do you tell the difference between a cast or steel crank?
Re: Cast or Steel Crank? [Re: FiveWoods] #132822
10/06/08 10:16 AM
10/06/08 10:16 AM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
If its a 440 crank, one way to tell them apart is to examine the crank for a raised up cast "440" on one of the counterweights, not stamped in but raised. If you find that, it is cast. The other way is to look at the seperating lines but that is difficult to explain here (better in a photo). Of course, if you have the original balancer, it will be thick and have "440 cast only" or something like that on it.
Re: Cast or Steel Crank? [Re: FiveWoods] #132823
10/06/08 10:25 AM
10/06/08 10:25 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Could be difficult if all you have to look at is one crank but if you have two and one has a rougher appearance to the non-machined surfaces than the other, it is probably cast. The forged crank should have a smoother appearance on the non-machined surfaces. There is a spark test that is often used also but it involves grinding and you probably shouldn't do any unnecessary grinding on a crank and sparks can be difficult to read unless you have some metalurgy background. Hope this is helpful. Yeah, and what repad said!!
Re: Cast or Steel Crank? [Re: Scott Carl] #132824
10/07/08 01:15 AM
10/07/08 01:15 AM
dogdays Offline
dogdays  Offline
The first answer was the best. A cast crank will have squared-off counterweights and a number 440 cast onto the edge of the first conterweight. It's quite an easy ID. Or you could go to www.440Source.com and look at their stock crank pictures.
R.
Re: Cast or Steel Crank? [Re: dogdays] #132825
10/07/08 01:16 AM
10/07/08 01:16 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
