Re: 10 to1 383 or 8 to1 440?
[Re: Jimbo]
#1328161
10/29/12 04:40 PM
10/29/12 04:40 PM
RapidRobert
The 440 would have way more cubes and a non flat cam & as you know the RB block being 3/4" higher up at at 45 angle would take some different brackets in the front and maybe exhaust pipe mods & check carb height and you'll like a change but at an advertized 8.4 the actual CR may be in the sevens. As said I'd put a new cam/lifters in the 383 (Summit-$60) & gain some renewed power while you rebuild the 440 properly. That way your making/enjoying constant progress
[Re: RapidRobert]
#1328162
10/29/12 06:01 PM
10/29/12 06:01 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Interesting question and the real world answer has a bunch of variables, but looking at it theoreretically, most sources agree that a 10 point bump in compression (going from 8 to 9:1 for eg.) is worth about 3% in power so going from 8 to 10 would be maybe around 6% (though the effects of increased compression aren't linear).
....the 440 is 15% larger than the 383 so the 6 percent drop in power will be overshadowed by the increased displacement...all other things being equal.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DaytonaTurbo]
#1328165
10/29/12 06:59 PM
10/29/12 06:59 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Also, if you actually calculate the numbers, you will find a stock piston 383 is nowhere near 10:1 compression. So in reality you are probably more like comparing a 7.8:1 compression 70's smogger 440 to a 383 that has around 8.5 compression.
Depends on what year/flavor the 383 is , a 68/69 383 4 bbl , 330 or 335hp , compression is a measured 9.2ish ...
Either way the incorrect way to fix a lobe going flat is to just stab in another cam ...
[Re: 1_WILD_RT]
#1328166
10/29/12 07:08 PM
10/29/12 07:08 PM
Posts: 4,255 Canada
WO23Coronet
Canada
X2 440 all the way. Yeah rebuilding the 440 right would be nice but sometimes u just have to use what u have to get going, plus, if the cam all of a sudden went flat, the engine would be contaminated with metal filings and have to be yanked and cleaned anyway. If its a gradual thing u could get away with recamming the 383.
Put a Summit cam in the 440, drop it in and giver
[Re: Jimbo]
#1328168
10/30/12 04:24 PM
10/30/12 04:24 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
thanks for the response guys, first off, the 383 is a 66 hi perf engine that came from a satellite. If i went with the 440, i was planning on doing a basic re-ring job, i have a set of 452 heads sitting here that came off a 17k motorhome motor that spun a bearing. money is tight, so this is a limited budget project. I'm just wondering if the payoff will be worth the extra money and time.
the closed chamber heads on the 383 would be a beter option as they would give you some more compression. The 440 wil have gobs more of torque and wil pull harder, faster than the 383.
[Re: Jimbo]
#1328169
10/30/12 05:12 PM
10/30/12 05:12 PM
DaytonaTurbo
Manitoba, Canada
Doesn't matter. Factory compression ratios were a lie. At best your 383 is 9:1 compression. Putting those open chamber 452's on there will drop you down even further. I've never owned a 383 but I can tell you that a 70's smogger 440 is a dog unless you put in some decent rear gears and a torq converter.
