Terminal spade source #1328140
10/29/12 02:42 PM
10/29/12 02:42 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hello All,
Was curious, I'm finding it extremely hard now to fine local auto part stores that sell the proper male/female spades for our wiring harnesses. Typically, when I have to repair a connection or make a harness for something (ignition system, aftermarket product, etc) I like to use OEM connectors and spades.... Any sources out there to purchase in bulk?
Thanks...
Troy
Houston Mopar Connection Club
Re: Terminal spade source [Re: hemi68charger] #1328141
10/29/12 03:40 PM
10/29/12 03:40 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Troy,
Tom has them. http://www.rtspecialties.net/
Im sure others do too but this was the first place I had saved that I know has the connectors.
Re: Terminal spade source [Re: LimeliteAero] #1328142
10/29/12 04:03 PM
10/29/12 04:03 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Napa carries them. Although I don't know the PN off hand.
Re: Terminal spade source [Re: hemi68charger] #1328143
10/29/12 05:33 PM
10/29/12 05:33 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here are 2 threads with Napa and Standard Ignition numbers and info.
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=7365500&Main=7365500
https://board.moparts.org/ubbthreads/show...fpart=&vc=1
Edit; added pic of some bought at Carquest. Boxes had same numbers as Standard Ignition uses.
Re: Terminal spade source [Re: moparfan53] #1328144
10/29/12 05:43 PM
10/29/12 05:43 PM
Alabama
BigMoneyLewis Offline
Alabama
You are probably looking for the 56 series packard terminals .
This company sells just about any 60's - 70's era factory terminal
you could want .
http://happyterminals.com/
Greg
gregward@mchsi.com phone 256-852-0955
