Tail Lens P/N application help needed. #132756
10/06/08 05:21 AM
10/06/08 05:21 AM
Phila
P
PhillyRag Offline OP
P
Phila
I've had a pair of mopar red/white rectangular, 4 cavity lens around for some years. Not sure of use. Can anyone help identify. P/N's on lens are 3478 860/861: LS & RS. Thank You
Re: Tail Lens P/N application help needed. [Re: PhillyRag] #132757
10/06/08 09:01 AM
10/06/08 09:01 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A picture would help.
Re: Tail Lens P/N application help needed. [Re: stumpy] #132758
10/07/08 02:17 AM
10/07/08 02:17 AM
Phila
P
P
Phila
Hope this helps. I'm not good with picture taking with a digital. Please see attachment pic.
Re: Tail Lens P/N application help needed. [Re: PhillyRag] #132759
10/07/08 04:21 AM
10/07/08 04:21 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
71 R/T- 72 Rallye Charger
LOT and incredibly FADED BTW!
Re: Tail Lens P/N application help needed. [Re: NachoRT74] #132760
10/08/08 02:58 AM
10/08/08 02:58 AM
Phila
P
P
Phila
Thank You for info. Pic aint the best, but they're red & clear lens--pic taken under room lights (yellowish).
What's this mean?
"LOT and incredibly FADED BTW! "
Re: Tail Lens P/N application help needed. [Re: PhillyRag] #132761
10/08/08 01:11 PM
10/08/08 01:11 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
all the lense should it be RED but the reverse
Re: Tail Lens P/N application help needed. [Re: NachoRT74] #132762
10/09/08 05:22 AM
10/09/08 05:22 AM
Phila
P
P
Phila
OK--but why do these have clear areas, for the brake light sections? Did they offer both clear & red? If you put amber bulbs there--you'd have amber colored brake light. Red Bulbs. These are original lens. Could they be some kind of "mistake" or fluke made by mistake?
Re: Tail Lens P/N application help needed. [Re: PhillyRag] #132763
10/09/08 09:22 AM
10/09/08 09:22 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
They just look WAY faded to me.....
Re: Tail Lens P/N application help needed. [Re: buildanother] #132764
10/09/08 09:25 AM
10/09/08 09:25 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I'm guessing that's the back side of the lens with the reflector showing. Light bulb behind the reflector will still shine through as red from the outside. Maybe a little scrubbing and flipping them over will show some better detail.
Clair
Re: Tail Lens P/N application help needed. [Re: Clair_Davis] #132765
10/09/08 10:12 AM
10/09/08 10:12 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Faded is my opinion also.
Re: Tail Lens P/N application help needed. [Re: stumpy] #132766
10/09/08 10:20 PM
10/09/08 10:20 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Looks like they were left laying in the sun for several years... Probably very brittle also if this is the case.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Tail Lens P/N application help needed. [Re: GO_Fish] #132767
10/10/08 06:51 AM
10/10/08 06:51 AM
Phila
P
P
Phila
No-came out of a junkyard trailer, where stored for years. These were complete assemblies: lens, bezels, housings. I've NEVER seen red plastic lens fade into WHITE.
Here's a pic of the backside of lens.
Re: Tail Lens P/N application help needed. [Re: PhillyRag] #132768
10/10/08 06:54 AM
10/10/08 06:54 AM
Phila
P
P
Phila
Another pic. this time with a floursecent backlit rather then front flash.
Re: Tail Lens P/N application help needed. [Re: PhillyRag] #132769
10/11/08 05:18 AM
10/11/08 05:18 AM
Phila
P
P
Phila
I'll pose another question?
Was there ever a situation where tail lamp lens were clear? Off Road, Overseas, etc?
Re: Tail Lens P/N application help needed. [Re: PhillyRag] #132770
10/20/08 12:07 AM
10/20/08 12:07 AM
Phila
P
P
Phila
Anybody have means to check the p/n of these lens? THanx
Re: Tail Lens P/N application help needed. [Re: PhillyRag] #132771
10/20/08 04:08 AM
10/20/08 04:08 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Do you see a parting seam between the red and clear colors? If not their faded.
Re: Tail Lens P/N application help needed. [Re: PhillyRag] #132772
10/20/08 11:47 AM
10/20/08 11:47 AM
US of A
A38s! Offline
A38s!  Offline
US of A
Do the lenses read "SAE" somewhere on them, or no?
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: Tail Lens P/N application help needed. [Re: Clair_Davis] #132773
10/20/08 01:44 PM
10/20/08 01:44 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Clair
these models didn't came with reflectors like some other models on late years... the reflector/refractor is the same lense
Re: Tail Lens P/N application help needed. [Re: PhillyRag] #132774
10/20/08 01:48 PM
10/20/08 01:48 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
into CLEAR to be exact... NEVER I DID EITHER, AND I LIVE IN A TROPICAL COUNTRY... Venezuela.
BUT lense is one piece except the back up clear what is inserted and glued. There is no way to make two tones lense in one piece.
Onece again. I dunno how, but is FADED.
You can notice also the faded area on louvers slots areas what are the only ones exposed throught the bezel beside the squared ones.
