Paint for Steering Column #1327391
10/28/12 04:03 PM
10/28/12 04:03 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Guys,
I have torn down my steering column as I needed to swap out the turn signal handle and the ignition cylinder.
While I have it torn down, I need to repaint it to make it pretty again where it had some scratches/chips from getting beat on when the car was being resored.
What kind of paint should I use to paint this? I have the three housings which are made of aluminum. I have them sanded down well (still mostly painted but sanded well) to a 320 grit.
The paint doesn't have to exactly factory but I want it to be close if possible. What do you guys use to paint the column which looks factory (least close) and will hold up well?
EDIT: Steering column is black.
Thanks!
Re: Paint for Steering Column [Re: cjskotni] #1327392
10/28/12 08:53 PM
10/28/12 08:53 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
SEM trim black
Re: Paint for Steering Column [Re: AdamR] #1327393
10/29/12 10:19 AM
10/29/12 10:19 AM
SE Pa.
LimeliteAero Offline
SE Pa.
you didnt note what year and model youre working on??
Im going out on a limb without knowing and say you need Mike Mancinni's suede finish paint, its a little pricey but its exactly what the factory used. Your local PPG supplier may be able to mix the suede but most cannot.
I just looked at your signature and guess thats what youre restoring...so the above should be be what you need.
Re: Paint for Steering Column [Re: LimeliteAero] #1327394
10/29/12 12:26 PM
10/29/12 12:26 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
TCP Global can mix it a lot cheaper then Mike Mancini is selling it for,
Re: Paint for Steering Column [Re: AdamR] #1327395
10/29/12 01:45 PM
10/29/12 01:45 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I use Rustoleum TEXTURE black (number 7220 ) or Dupicolor semi gloss black on the non textured parts. You can dry spray the dupicolor paint to get the textured look as well.
Re: Paint for Steering Column [Re: THESHAKERPROJECT] #1327396
10/29/12 02:33 PM
10/29/12 02:33 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
The Rustoleum or Tremclad texture paints, if dry-sprayed look quite presentable and aren't as blatantly wrong as regular, untextured paint.
Re: Paint for Steering Column [Re: THESHAKERPROJECT] #1327397
10/29/12 07:23 PM
10/29/12 07:23 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
Re: Paint for Steering Column [Re: MAVERICKSHEMI] #1327398
10/30/12 04:33 PM
10/30/12 04:33 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I found this paint and got it on after two coats of primer. Looks very nice so far! I am going to wait a day or so and then throw on a second coating to make it tougher.
Would I want to clear coat this and what would I use? I have some Eastwood Diamond Clear Satin but I am afraid that will gloss it up more than I want. I am also not totally sure it won't damage the top coat.
Rustoleum has their clear coat but they are all hi-gloss which is not the direction I want to go in here.
Any ideas what I can use here or should I just leave it as is?
Thanks!
Re: Paint for Steering Column [Re: cjskotni] #1327399
10/30/12 04:41 PM
10/30/12 04:41 PM
YYZ Offline
YYZ  Offline
Just leave it. Don't clear coat it
Re: Paint for Steering Column [Re: YYZ] #1327400
10/30/12 05:10 PM
10/30/12 05:10 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
The steering column gets a lot of "traffic" Is this going to hold up without the clear?
Re: Paint for Steering Column [Re: cjskotni] #1327401
10/30/12 09:47 PM
10/30/12 09:47 PM
california
Mr D21 Offline
Mr D21  Offline
california
traffic? Just make sure your dont "miss" when inserting that key and dont have other keys dangling and your column will stay very nice....
Re: Paint for Steering Column [Re: Mr D21] #1327402
10/31/12 02:59 AM
10/31/12 02:59 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
The correct color is available from PPG.The interior colors are on the back of the color charts for the body colors.
Leave the gun.......take the Cannoli's....Mike
Re: Paint for Steering Column [Re: cjskotni] #1327403
10/31/12 05:27 PM
10/31/12 05:27 PM
NASHVILLE
NASHVILLE
Thanks!
I know this sounds crazy but keep it warm... you will see a difference over the next 30 days... I would not clear coat it,, just let it be.. will take 6 weeks to totally set up.. Thats how it worked on my car...
I am talking about TEXTURE BLACK.. If you get to much texture or grainy,, go back over with Resto plain Black Satin....
Re: Paint for Steering Column [Re: AdamR] #1327404
10/31/12 07:33 PM
10/31/12 07:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
SEM trim black
This is not a bad idea, I have used it and it looks good, very close.
What year and model car are we asking about?
Re: Paint for Steering Column [Re: AdamR] #1327405
11/02/12 12:19 AM
11/02/12 12:19 AM
Mass
Mike Mancini Offline
Mass
This may be true, but they are using the currently available texture additive that is way too coarse and will not achieve a factory testure, you won't even be able to run a cloth over it without snagging and shredding.
Ours is mixed using probably the last or the original formula suede additive on the planet. I have limited supplies and once it is gone, it's gone.
Re: Paint for Steering Column [Re: Mike Mancini] #1327406
11/03/12 02:26 PM
11/03/12 02:26 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
mike,
i have a 68 cuda fastback. would you have the correct suede paint for the dash and the steering column? it is maroon. also how about the correct paint for all the other trim? thanks
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
