Need Addco/Hellwig rear sway bar pics for A-body #132735
10/06/08 02:43 AM
10/06/08 02:43 AM
Anywhere the British Secret Se...
Moonraker Offline OP
Have one I want to install and I think everything is there(used). Pics would help if anyones got them, and for polyurethane end link bushings how tight are you supposed to tighten them?
Re: Need Addco/Hellwig rear sway bar pics for A-body [Re: Moonraker] #132736
10/06/08 03:41 AM
10/06/08 03:41 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I posted a pretty detailed pic in the other thread?
https://board.moparts.org/ubbthreads/show...e=0#Post4731658
again from 68 Dart. For an Addco bar. Older Helwig should be same.
68 Barracuda A-body (yes,I have exhaust issues but did put a new hanger on the passenger side)
Re: Need Addco/Hellwig rear sway bar pics for A-body [Re: Moonraker] #132737
10/06/08 07:05 AM
10/06/08 07:05 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Re: Need Addco/Hellwig rear sway bar pics for A-body [Re: Moonraker] #132738
10/06/08 11:04 AM
10/06/08 11:04 AM
Does anyone have a close-up of the brackets that attach it to the rear end so I can see how they're assembled? Thanks for the other pics to.
Re: Need Addco/Hellwig rear sway bar pics for A-body [Re: Moonraker] #132739
10/06/08 11:05 AM
10/06/08 11:05 AM
Is there any torque specs for the end links? I dont want to tighten the poly bushings I have to much. Thanks guys!
Re: Need Addco/Hellwig rear sway bar pics for A-body [Re: Moonraker] #132740
10/06/08 11:53 AM
10/06/08 11:53 AM
GMP440 Offline
GMP440  Offline
I clicked on the link that gets you on the A-bodies site in reference to the helwig swaybar and noted the dog bone type of rear swaybar endlinks and swaybar. What ocurred to me, is that particular sway bar is the same shape as the 79' through 91' Ford Crown Vic rear swaybar which if it measures right could possibly be used on A-bodies and b-bodies. Lots of these Ford cars are in junkyards and those swaybars can be gotten for about $10. At least that's the price at the yards I go to.
