.120 or .080 wall tube for back halfed dart? #1326438
10/26/12 08:59 AM
10/26/12 08:59 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I am back halfing a dart and was looking at sw racecars for frame rails since they are close. They only have .080 wall 2x3 . Is this thick enough? I thought most people used .120 ?
Re: .120 or .080 wall tube for back halfed dart? [Re: dirt] #1326439
10/26/12 10:10 AM
10/26/12 10:10 AM
gregsdart Offline
gregsdart  Offline
If you use what they sell the way they want you too, it should be just right. I went thicker, but wish I hadn't due to added weight.
Re: .120 or .080 wall tube for back halfed dart? [Re: gregsdart] #1326440
10/26/12 11:25 AM
10/26/12 11:25 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
I just finished a backhalf on my Dart i made my own rails using rect. mild steel 2x3x.083 as i pieced it together id physically try flexing the rails and as i added bars such as the down bars it would stiffen but i could still see some flex so i added X bars and a few extra lightweight tubes to get it stiffened up, so by the time it was finished i shoulda just used .120 or .095, i also had a heavy friend who i had to grab the rails and try moving them so i could see where the flexing was occurring, its very stiff but as i said next time id look for somthing thicker than .083 mild steel on a frame structure
Re: .120 or .080 wall tube for back halfed dart? [Re: Cheatham] #1326441
10/26/12 11:30 AM
10/26/12 11:30 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
I use .083 but I make my bars go thru the 2x3 and weld on both sides
Re: .120 or .080 wall tube for back halfed dart? [Re: SB412DUSTER] #1326442
10/26/12 11:54 AM
10/26/12 11:54 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
Thanks for the advice. S&w is close and if i get the rear frame and roll cage from them it really saves money on shipping and the frame rails were only $250. I would spend at least 1 day or a little more making them my self. There supposed to be contoured to fit the floor.so i can keep most of the trunk. Probably just cut out the spare tire well.and widen wheel tubs.
Running the tube throuhg and welding sounds like a good idea too, that keeps from tearing the side of tube out.
Re: .120 or .080 wall tube for back halfed dart? [Re: dirt] #1326443
10/28/12 08:29 PM
10/28/12 08:29 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Unless you are building a streetrod with no cage. Use .083". Anything more is a waste.
Re: .120 or .080 wall tube for back halfed dart? [Re: Leon441] #1326444
10/28/12 10:55 PM
10/28/12 10:55 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I agree. The Chassis Engineering backhalf kit I used on my old Duster had .083 wall frame rails, and I never had any issue whatsoever.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: .120 or .080 wall tube for back halfed dart? [Re: DusterDave] #1326445
10/28/12 11:26 PM
10/28/12 11:26 PM
ohio
W
wj440 Offline
wj440  Offline
W
ohio
Thats all i use...from s&w.
