Page 2 of 3 1 2 3
Re: 68 charger conversion to 69 dayclona ? [Re: daytona kid] #1326124
11/01/12 11:48 PM
11/01/12 11:48 PM
Milwaukee WI
R_Blaha Offline
R_Blaha  Offline
Milwaukee WI
I would build it like the 68 in the movie Christine!!! Blue with some Cragar S/S!!!!
Save your cash on the daytona clone parts and build a 496 stroker from muscle motors and keep the "sleeper" image alive on this car!! Daytonas are cool, but clones of them are played out!
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT
1969 Dodge Superbee post coupe 383
1969 Dodge Superbee hardtop 472 hemi
1989 Mustang GT
1993 mustang lx 5.0
2004 screaming yellow cobra
2013 CVO Roadglide
Re: 68 charger conversion to 69 dayclona ? [Re: R_Blaha] #1326125
11/02/12 07:53 PM
11/02/12 07:53 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
The engine could be a 440 , would need a close look at the front of the engine to verify....just across from the dist.
Re: 68 charger conversion to 69 dayclona ? [Re: R_Blaha] #1326126
11/02/12 09:13 PM
11/02/12 09:13 PM
daytona kid Offline OP
Funny, I think my charger was about that color blue, maybe a little lighter blue tho, and I like that charger in christine also., And love the movie. One of my old RR's was possessed and would drive itself without me steering. Actually, it pulled a little to the left and the brakes pulled to the right. I freaked out a lot of my friends.
Re: 68 charger conversion to 69 dayclona ? [Re: mopar_man] #1326127
11/02/12 09:15 PM
11/02/12 09:15 PM
I hope it is, How can I tell? What would I see across from the dist? Numbers?
Re: 68 charger conversion to 69 dayclona ? [Re: daytona kid] #1326128
11/03/12 10:44 PM
11/03/12 10:44 PM
Re: 68 charger conversion to 69 dayclona ? [Re: daytona kid] #1326129
11/03/12 11:37 PM
11/03/12 11:37 PM
Chilly Northern, Minn.
71 Charger R/T Offline
here's a link to some pics> http://s1284.beta.photobucket.com/user/daytonakid/library/68%20charger
"This is a private album" ...........need password
Re: 68 charger conversion to 69 dayclona ? [Re: 71 Charger R/T] #1326130
11/03/12 11:50 PM
11/03/12 11:50 PM
Re: 68 charger conversion to 69 dayclona ? [Re: daytona kid] #1326131
11/04/12 05:44 PM
11/04/12 05:44 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
My my...you have absolutely got yourself a project there...good luck and hang in there...
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: 68 charger conversion to 69 dayclona ? [Re: daytona kid] #1326132
11/04/12 07:18 PM
11/04/12 07:18 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
in front of the intake, to the drivers side of the distributer, if there is a flat pad, about the width of 3 fingers, it's a 440. if the pad is there it will be stamped with a letter, then the engine size. example E440 would be 1969 440.
looks like a great project, and I vote for the Christine Charger!
1981 Dodge D150 360 auto
Re: 68 charger conversion to 69 dayclona ? [Re: basketcase] #1326133
11/04/12 11:36 PM
11/04/12 11:36 PM
I gota remove the ac unit to see that area, will do soon..Does the color mean anything?. This one is blue. Are the 383s blue? I saw a blue 440 somewhere.
Re: 68 charger conversion to 69 dayclona ? [Re: daytona kid] #1326134
11/05/12 11:33 PM
11/05/12 11:33 PM
OK, It is a 383, I see a B on the block. I want to make some HP with a motor. I may have found a 78 new-yorker or something like that with a 440 in it, running for $800. Would I be able to make more HP cheaper,easier or be better off with that 440 rather than the 383? I am willing to put a couple grand or so in the motor rebuild. Thinking of building a mild but stout motor and adding a nitrous system for when I go to the local strip.
Re: 68 charger conversion to 69 dayclona ? [Re: daytona kid] #1326135
11/06/12 12:48 AM
11/06/12 12:48 AM
Just build the 383, it will be great with nitrous.
Re: 68 charger conversion to 69 dayclona ? [Re: ] #1326136
11/06/12 08:43 PM
11/06/12 08:43 PM
Rgr tht SF,
I found some bad rust on the 2 rear frame beams.,I,ve got a rotisserie ready for it when I get it apart, but scared to bolt it to a the rusty a$$ beams before I replace or repair them....
So how much more trouble/$ would it be to tub it? and put in a roll cage, etc.? Did you tub your Coronet? If so I sure would like to see some pics and get some info on how to do it if you would be so kind.
Re: 68 charger conversion to 69 dayclona ? [Re: daytona kid] #1326137
11/08/12 01:22 AM
11/08/12 01:22 AM
Check my project out in this section - ( Carpenters Special ) I have the whole build documented. I made my own frame rails but if one is not to savy with the tools then you can buy a back half kit from quite a few vendors. If you don't want to tubb it get some replacement rails and change the old ones out. Tubbing is a lot of work when you make everything needed including all the brackets. I am doing my car for the fun of it because I really enjoy working on cars. It has been a learning process and I would definitely have done things differently had I known better but hay....... now I know better.
Re: 68 charger conversion to 69 dayclona ? [Re: ] #1326138
11/08/12 01:28 AM
11/08/12 01:28 AM
I forgot to add that I am totally an old school big tire car guy so I say tubb it........... you won't be sorry until after you add up the receipts. Where abouts are you located?
Robert
Re: 68 charger conversion to 69 dayclona ? [Re: ] #1326139
11/08/12 10:39 PM
11/08/12 10:39 PM
I live in the midsouth of America.Why? I found a great series of vids on youtube about tubbing and restoring B bods. And saw some about mini tubbing?, Do you have to move the frame rails and leafs and cut axles to mini tub?
Re: 68 charger conversion to 69 dayclona ? [Re: daytona kid] #1326140
11/09/12 02:30 AM
11/09/12 02:30 AM
When you mini tub the frame rails stay in the stock location. You can buy a kit for mini tubbing which moves the springs inboard. The kit has two boxes that go into the lower frame rail which you have to cut and then weld the boxes in. The rear shackles will mount on the frame rails. Then you separate the wheel houses and add a piece in between after cutting the trunk floor on either side.
Re: 68 charger conversion to 69 dayclona ? [Re: ] #1326141
11/09/12 08:19 PM
11/09/12 08:19 PM
That sounds like the way to go for me. THnx for sharing that.
Re: 68 charger conversion to 69 dayclona ? [Re: daytona kid] #1326142
11/21/12 09:45 PM
11/21/12 09:45 PM
OK, I think I have decided on how I'm going to go back up with this car. I enjoyed drag racing in my younger years so I'm am going to make it into a streetable strip ripper. Think I may paint it red (maybe fake r/t) with black (partial) interior, .,mini tubs for street legal M/T fatty radial slicks. I am going to find a 440 and stroke it to 500ci pump gasable with 10-1 or so pistons, aluminum heads, mild cam.
That said, I don't see much point of puting a lot back factory dress. I'm not going to be driving it that much and won't need stuff like the ac, heater, radio, back seat, etc.. I'm going with 2 semi-racing bucket seats up front, and shiny sheet metal aluminum everywhere inside with maybe a little black carpet. A 6or8 pt roll cage, maybe even wheelie bars. Maybe a 10 gal fuel cell.
I am thinking of selling the stuff I don't need (locally, no shipping), like the seats, console, a/c, etc. About what should I be able to get for the seats? Here is a link to a pic of the fronts., the back seat is same condition as fronts.
http://s1284.beta.photobucket.com/user/daytonakid/media/68%20charger/IMAG0674.jpg.html
Re: 68 charger conversion to 69 dayclona ? [Re: daytona kid] #1326143
11/22/12 01:32 PM
11/22/12 01:32 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Seeing as how you started your thread with a post about value, I thought I'd point out that tubbing and changing it to a resale red partial clone/racecar without an interior is about the worst thing you could possibly do for resale value.
...if you don't care about future value, then ignore the above.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Page 2 of 3 1 2 3
