Re: 68 charger conversion to 69 dayclona ?
[Re: daytona kid]
#1326124
11/01/12 11:48 PM
11/01/12 11:48 PM
Posts: 1,898 Milwaukee WI
R_Blaha
Milwaukee WI
I would build it like the 68 in the movie Christine!!! Blue with some Cragar S/S!!!! Save your cash on the daytona clone parts and build a 496 stroker from muscle motors and keep the "sleeper" image alive on this car!! Daytonas are cool, but clones of them are played out!
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT 1969 Dodge Superbee post coupe 383 1969 Dodge Superbee hardtop 472 hemi 1989 Mustang GT 1993 mustang lx 5.0 2004 screaming yellow cobra 2013 CVO Roadglide
[Re: R_Blaha]
#1326126
11/02/12 09:13 PM
11/02/12 09:13 PM
daytona kid
Funny, I think my charger was about that color blue, maybe a little lighter blue tho, and I like that charger in christine also., And love the movie. One of my old RR's was possessed and would drive itself without me steering. Actually, it pulled a little to the left and the brakes pulled to the right. I freaked out a lot of my friends.
[Re: daytona kid]
#1326132
11/04/12 07:18 PM
11/04/12 07:18 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
in front of the intake, to the drivers side of the distributer, if there is a flat pad, about the width of 3 fingers, it's a 440. if the pad is there it will be stamped with a letter, then the engine size. example E440 would be 1969 440. looks like a great project, and I vote for the Christine Charger!
1981 Dodge D150 360 auto
[Re: daytona kid]
#1326134
11/05/12 11:33 PM
11/05/12 11:33 PM
daytona kid
OK, It is a 383, I see a B on the block. I want to make some HP with a motor. I may have found a 78 new-yorker or something like that with a 440 in it, running for $800. Would I be able to make more HP cheaper,easier or be better off with that 440 rather than the 383? I am willing to put a couple grand or so in the motor rebuild. Thinking of building a mild but stout motor and adding a nitrous system for when I go to the local strip.
[Re: daytona kid]
#1326135
11/06/12 12:48 AM
11/06/12 12:48 AM
Just build the 383, it will be great with nitrous.
[Re: daytona kid]
#1326137
11/08/12 01:22 AM
11/08/12 01:22 AM
Check my project out in this section - ( Carpenters Special ) I have the whole build documented. I made my own frame rails but if one is not to savy with the tools then you can buy a back half kit from quite a few vendors. If you don't want to tubb it get some replacement rails and change the old ones out. Tubbing is a lot of work when you make everything needed including all the brackets. I am doing my car for the fun of it because I really enjoy working on cars. It has been a learning process and I would definitely have done things differently had I known better but hay....... now I know better.
[Re: ]
#1326138
11/08/12 01:28 AM
11/08/12 01:28 AM
I forgot to add that I am totally an old school big tire car guy so I say tubb it........... you won't be sorry until after you add up the receipts. Where abouts are you located?
Robert
[Re: daytona kid]
#1326140
11/09/12 02:30 AM
11/09/12 02:30 AM
When you mini tub the frame rails stay in the stock location. You can buy a kit for mini tubbing which moves the springs inboard. The kit has two boxes that go into the lower frame rail which you have to cut and then weld the boxes in. The rear shackles will mount on the frame rails. Then you separate the wheel houses and add a piece in between after cutting the trunk floor on either side.
[Re: ]
#1326141
11/09/12 08:19 PM
11/09/12 08:19 PM
daytona kid
That sounds like the way to go for me. THnx for sharing that.
[Re: daytona kid]
#1326142
11/21/12 09:45 PM
11/21/12 09:45 PM
daytona kid
OK, I think I have decided on how I'm going to go back up with this car. I enjoyed drag racing in my younger years so I'm am going to make it into a streetable strip ripper. Think I may paint it red (maybe fake r/t) with black (partial) interior, .,mini tubs for street legal M/T fatty radial slicks. I am going to find a 440 and stroke it to 500ci pump gasable with 10-1 or so pistons, aluminum heads, mild cam. That said, I don't see much point of puting a lot back factory dress. I'm not going to be driving it that much and won't need stuff like the ac, heater, radio, back seat, etc.. I'm going with 2 semi-racing bucket seats up front, and shiny sheet metal aluminum everywhere inside with maybe a little black carpet. A 6or8 pt roll cage, maybe even wheelie bars. Maybe a 10 gal fuel cell. I am thinking of selling the stuff I don't need (locally, no shipping), like the seats, console, a/c, etc. About what should I be able to get for the seats? Here is a link to a pic of the fronts., the back seat is same condition as fronts. http://s1284.beta.photobucket.com/user/daytonakid/media/68%20charger/IMAG0674.jpg.html
[Re: daytona kid]
#1326143
11/22/12 01:32 PM
11/22/12 01:32 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Seeing as how you started your thread with a post about value, I thought I'd point out that tubbing and changing it to a resale red partial clone/racecar without an interior is about the worst thing you could possibly do for resale value. ...if you don't care about future value, then ignore the above. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
