V 10 IDLE AIR CONTROL #1325997
10/25/12 04:52 PM
10/25/12 04:52 PM
OHIO
BUBBAZ572 Offline OP
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
IDLE AIR CONTROL VALVE ON 98 V10 TRUCK MAKES VERY LOUD WHISTLE NOISE.
HAVE CHANGED VALVE TWICE AND STILL HAVE THE SAME PROBLEM.THERE ARE NO VACUUM LEAKS AROUND THROTTLE BODY.
ANY BODY OUT THERE HAVE A SIMILER PPOBLEM?
Re: V 10 IDLE AIR CONTROL [Re: BUBBAZ572] #1325998
10/25/12 08:19 PM
10/25/12 08:19 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
ALL I CAN HEAR IS A LOUD WHISTLE!
ANYONE ELSE?
Mo' Farts
Moderated by "tbagger".
Re: V 10 IDLE AIR CONTROL [Re: BUBBAZ572] #1325999
10/26/12 08:27 AM
10/26/12 08:27 AM
Indiana
litngetr Offline
litngetr  Offline
Indiana
Have you tried cleaning the IAC passage.
Re: V 10 IDLE AIR CONTROL [Re: litngetr] #1326000
10/26/12 05:52 PM
10/26/12 05:52 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
YES IT HAS ALL BEEN CLEANED.
Re: V 10 IDLE AIR CONTROL [Re: BUBBAZ572] #1326001
10/26/12 07:29 PM
10/26/12 07:29 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Since you have cleaned it and replaced it twice are you sure it's the IAC?
A cracked exhaust manifold can make the same sound.
Mo' Farts
Re: V 10 IDLE AIR CONTROL [Re: Grizzly] #1326002
10/29/12 10:01 AM
10/29/12 10:01 AM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
YES THE IAC. I CAN PUT MY FINGER IN THE HOLE AND THE WHISTLE WILL GET QUIETER.
NO CRACKED MANIFOIDS,HAVE NEW HEDDERS
Re: V 10 IDLE AIR CONTROL [Re: BUBBAZ572] #1326003
10/30/12 11:30 AM
10/30/12 11:30 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Bubba, do us a favor and look at your keyboard. Just to the left of the letter A is a key marked Caps Lock. Please press that before writing your next post.
- Stu Harmon
Re: V 10 IDLE AIR CONTROL [Re: feets] #1326004
10/30/12 04:11 PM
10/30/12 04:11 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
I AM TRING TO SOLVE A PROBLEM.
I DO NOT NEED ANY BS FROM YOU!
IF YOU DO NOT HAVE AN ANSWER THE PROBLEM I DO NOT NEED THE BS FROM YOU.
IF THIS IS ALL YOU HAVE TO DO,STAY OFF OF THE SITE
THANKS FOR NOTHING.
Re: V 10 IDLE AIR CONTROL [Re: BUBBAZ572] #1326005
10/30/12 04:27 PM
10/30/12 04:27 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
THANKS FOR NOTHING.
Wow. You were almost as friendly here as you were in that note you sent me.
HEY ASS [Edited by Moparts - Family Friendly Site - Keep it clean]?
I DO IT THE WAY I WANT TO.
YOU DONT LIKE IT GO [Edited by Moparts - Family Friendly Site - Keep it clean] YOUR SELF
I see you still haven't found that Caps Lock key.
Using all upper case letters is commonly thought of as SHOUTING at someone. Common courtesy calls for fixing that, especially when you're asking for help.
No doubt that your fine display of respect will encourage others to go out of their way to offer assistance.
- Stu Harmon
