Electronic Ignition Setup Ques #132597
10/05/08 08:49 PM
10/05/08 08:49 PM
Jackson, Mississippi
CornDogsCharger Offline OP
How do these generic electronic ignition kits compare to the Mopar Performance kits? Has anyone here used one of these kits on their small block. Tell me the pros and cons of these kits compared to the MP kit. MP kit goes for $215 now and these kits go for around $145. Thanks
Justin
"CornDog"
1966 Dodge Charger
1968 Plymouth Satellite (Un-Restored "Survivor")
1969 Dodge Charger (W.B. General Lee)
1969 Dodge Charger (Future DMCL Clone)
1969 Dodge Super Bee, 383 4spd
Re: Electronic Ignition Setup Ques [Re: CornDogsCharger] #132598
10/05/08 08:54 PM
10/05/08 08:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Use it will be fine.
When I do a conversion I use JY pieces most of the time. They work fine too.
Re: Electronic Ignition Setup Ques [Re: MoparforLife] #132599
10/05/08 08:56 PM
10/05/08 08:56 PM
JY ??
1966 Dodge Charger
Re: Electronic Ignition Setup Ques [Re: CornDogsCharger] #132600
10/05/08 08:58 PM
10/05/08 08:58 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
JY = Junk Yard
Re: Electronic Ignition Setup Ques [Re: CornDogsCharger] #132601
10/05/08 09:00 PM
10/05/08 09:00 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
You can buy junk yard parts and peform the conversion yourself. Really not hard.
Here is the diagram and info:
http://www.moparts.org/Tech/Archive/elec/3.html
Re: Electronic Ignition Setup Ques [Re: NTOLERANCE] #132602
10/05/08 09:13 PM
10/05/08 09:13 PM
Junkyard... gotcha. haha. Well, I guess I should clarify my point a bit. I have a '73 Dart Sport with a /6. I am dropping in a '87 Ramcharger 318/727 that I rebuilt. The Dart already has the elec. ignition setup. I guess I am just looking for something a little more than stock. Are the Mopar Perf. kits anything more than stock?
If I do use an OEM distributor, then is there much I can do to it to improve the perforamnce? Thanks!
Justin
"CornDog"
1966 Dodge Charger
Re: Electronic Ignition Setup Ques [Re: CornDogsCharger] #132603
10/05/08 09:27 PM
10/05/08 09:27 PM
Iron Station, NC
furygt Offline
furygt  Offline
Iron Station, NC
The wiring harness is the same MOPAR Performance part that comes in the kit.
The main difference is that the distributor is a stock type electronic distributor whereas the MP kit distributor is made for them by one of the big name performance companies whose name escapes me at the moment and the MP distributor is set up (curve, springs etc...) for an engine with higher than stock horsepower etc. The electronic ignition module is a stock replacement type whereas the MP kit provides either the orange or chrome boxes which are designed to be compatible for an engine that sees higher RPM's than a stock engine.
The old MP kits may have provided a race only voltage regulator for 69 & older MOPARS.
If you are installing an electronic ignition set up in a 69 & older car you do need to change the voltage regulator over to either the 70 & up type or you need to buy a solid state voltage regulator as the stock mechanical type 69 & older regulators will not work with an electronic ignition. If you do a conversion on a 69 & older car and want to retain a stock looking voltage regulator, see (my) eBay auction, number 180295901456 for the correct appearance solid state voltage regulators that I sell for a shipped price that is $5 less than a major MOPAR Restoration Parts company sells the same item for without shipping.
An alternative to buying the kit is to build one yourself by purchasing the parts separately. From a Chrysler dealer or other Mopar Performance parts dealer, purchase part # P3690152 wiring harness.
As for Ignition Module Selection;
With a four pin electronic ignition module you can use a ballast resistor with two pins.
A 5 pin module requires the dual ballast resistor and associated wiring.
To use a 4 pin control module with the # P3690152 wiring harness and a two pin ballast resistor just eliminate the wire going to pin 3 on the module and use a single element two pin ballast resistor for.
I strongly recommend mounting the ignition module away from direct heat and on a bracket that allows air to flow behind the module as the factory did with most of their installations.
If your engine is relatively stock, you do not need the MP kit. I suspect that the kit you are looking at is on eBay from seller CJMP and he is a very reputable person to deal with.
I hope this helped - feel free to email me with questions. I am going to try to post a wiring diagram within this reply.
Bill
Re: Electronic Ignition Setup Ques [Re: CornDogsCharger] #132604
10/05/08 09:46 PM
10/05/08 09:46 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Justin
"CornDog"
The kit won't be an upgrade. It's jsut a stock install. A points repalcement setup.
Realistically, your car is already electronic so all you need is a distributor for it to run.
If you want to do some upgrades, curve the distributor(either yourself, or a pro) and buy some upgraded parts. Like a chrome ecu and a high output coil.
Re: Electronic Ignition Setup Ques [Re: dave571] #132605
10/06/08 08:13 AM
10/06/08 08:13 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Mallory makes the new Mopar dizzy's.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Electronic Ignition Setup Ques [Re: CJK440] #132606
10/06/08 11:38 AM
10/06/08 11:38 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
The MP unit has an adjustable mechanical advance as well as an adjustable vacuum advance.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Electronic Ignition Setup Ques [Re: CornDogsCharger] #132607
10/06/08 12:01 PM
10/06/08 12:01 PM
GMP440 Offline
GMP440  Offline
I did not use the kits either. Got the distributer and harness from the junkyard and new electronic module at Advance Auto. I took the distributer apart, lubed it, put it back together, installed it along with the harness.
It all worked well. Total cost for everything; maybe $25.00.
Re: Electronic Ignition Setup Ques [Re: GMP440] #132608
10/06/08 01:22 PM
10/06/08 01:22 PM
5thAve Offline
5thAve  Offline
A big part of the price difference is the MP kit comes with a new distributor and if you just want that you can buy it separately at the dealer. This is the 1st I heard that it comes with a voltage regulator. You can get the wiring harness at the dealer too if you need it or just modify the one thats already on the car if you need to for the V8. You dont need anything else.
Re: Electronic Ignition Setup Ques [Re: 5thAve] #132609
10/06/08 01:34 PM
10/06/08 01:34 PM
Ozark Mo.
BADBEE Offline
BADBEE  Offline
Ozark Mo.
Anyone have directions on how to recurve a distibutor?
Or does that come with the spring kit? I pressume there is a spring kit that someone is selling???
Re: Electronic Ignition Setup Ques [Re: BADBEE] #132610
10/06/08 03:10 PM
10/06/08 03:10 PM
michigan
black64 Offline
black64  Offline
michigan
To recurve the distributor you need to know when you want the timing to come in(RPM) and how much. You should have access to a distributor machine to check the timing changes at rpm. It can be done in the car with a good timing lite but is a lot easier out of the car on the distributor machine.
Re: Electronic Ignition Setup Ques [Re: black64] #132611
10/06/08 04:45 PM
10/06/08 04:45 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
The Mallory spring kit #29014 (also under a MP#) has curves for timing verse rpm for the various springs along with spacers to set the mechanical advance in two degree increments.
The kit info is accurate enough that you don't need a distributor machine to set the distributor up.
