round 0 rings for wilwoods #1325886
10/25/12 12:18 PM
10/25/12 12:18 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I've just put fresh 0 rings in some wilwoods i've just fitted, cleaned all the pistons up and brake cleaned the bores as well but they are still dragging some.
I found a thread on classracer.com and they suggested using round seals, instead of the square one from wilwood.
Has anyone had a similar problem and these seals cured it and where did you get the seals from ?
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: round 0 rings for wilwoods [Re: deaks] #1325887
10/25/12 12:50 PM
10/25/12 12:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m interested also as mine drag too and if I can`t fix em then the`re gone and onto something better...........
Re: round 0 rings for wilwoods [Re: deaks] #1325888
10/25/12 01:19 PM
10/25/12 01:19 PM
Minn
SportF Offline
SportF  Offline
Minn
I believe the square seals retract the piston after pressure release, the round ones won't. I believe it was some Ford engineer that figured that out years ago and that's when they came to be. But, I could be wrong, but the square seal design seems to make sense in that respect.
Re: round 0 rings for wilwoods [Re: SportF] #1325889
10/25/12 01:42 PM
10/25/12 01:42 PM
Az
Crizila Offline
Crizila  Offline
Az
Square is the way to go. With pressure they actually deform in their grooves and when the pressure is released, they conform to their original shap, pulling the piston back a few thou.
Fastest 300
Re: round 0 rings for wilwoods [Re: Crizila] #1325890
10/25/12 02:05 PM
10/25/12 02:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I suppose I can call Wilwood for these or is there another source..........
Re: round 0 rings for wilwoods [Re: Thumperdart] #1325891
10/25/12 02:53 PM
10/25/12 02:53 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
It must be me then.. The pistons had no marks on them and the seals are new, as are the braided lines from summit. Master cylinder is newer one same as alloy one but the steel version. So i'm all out of ideas.
Mick
best 60ft 1.36
Re: round 0 rings for wilwoods [Re: deaks] #1325892
10/25/12 03:08 PM
10/25/12 03:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Most of what I`ve read about Wilwoods is that they drag more than others but there was a post a while back about a "trick" using a spring to back em off of the rotor when pedal is released............
Re: round 0 rings for wilwoods [Re: deaks] #1325893
10/25/12 05:27 PM
10/25/12 05:27 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I thought it was the round ones that "fixed" it. I know I have wilwoods front and rear with their master cylinder and mine drag. If I ever get my motor back I have thought about trying something similar to the stainless wishbone return springs like on ford truck discs.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: round 0 rings for wilwoods [Re: deaks] #1325894
10/25/12 05:35 PM
10/25/12 05:35 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
mine were dragging also when i changed seals. don't remember if they were round or square. i polished the pistons on a compound wheel till the little fine lines were gone. no more drag after that.
Re: round 0 rings for wilwoods [Re: 67HEMI] #1325895
10/25/12 05:35 PM
10/25/12 05:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What`s the story on this spring stuff?
Re: round 0 rings for wilwoods [Re: Thumperdart] #1325896
10/25/12 07:16 PM
10/25/12 07:16 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Maybe i should have done that, i used a scotchbrite pad, i didn't think those very faint lines would be a problem.
I'm taking the car out this weekend, so i'll leave it for now, i'll probably pull them apart over winter and see what can be done.
Mick
best 60ft 1.36
Re: round 0 rings for wilwoods [Re: Thumperdart] #1325897
10/25/12 07:17 PM
10/25/12 07:17 PM
67HEMI Offline
67HEMI  Offline
In the bottom right corner are the wishbone springs. The pads have a small hole drilled in the top edge of the brake pad backing plate at each end. After you put the pads in the caliper bracket you squeeze these springs together and stick the ends in the holes. Then the caliper piston housing sits on top of them and they keep tension outward on the pads.Only problem on wilwoods is there is nothing to keep the spring from coming out of the holes...but I am still working on that idea!
Re: round 0 rings for wilwoods [Re: 67HEMI] #1325898
10/25/12 07:49 PM
10/25/12 07:49 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i'd say the problem is the pistons. mine had fine (record like lines) on the pistons. after i polished those away, brakes work fine. a friend of mine had same problem with his front wilwoods, i buffed them & no more drag.
Re: round 0 rings for wilwoods [Re: rickraw] #1325899
10/25/12 08:28 PM
10/25/12 08:28 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Did you buff them with compound Rick ?
Mick
best 60ft 1.36
Re: round 0 rings for wilwoods [Re: deaks] #1325900
10/25/12 08:40 PM
10/25/12 08:40 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
yes. i used a 3/4" compound wheel with stainless rouge. had the pistons lookin like chrome & smooth.
Re: round 0 rings for wilwoods [Re: deaks] #1325901
10/26/12 10:22 AM
10/26/12 10:22 AM
PA
moparacer Offline
moparacer  Offline
PA
Mick
Yep I have always replaced the square seals with round ones. I get them from summit. Did you replace the pads when you rebuilt the calipers?
If the pads are worn crooked you cant use them. They will cock the pistons in the bore and make them hang up again. Also you cant let the brake pads wear down to the point the pistons push too far out of the bores and get crooked, and hang up.
I have dynalites and a spare set of them in the garage if you need the part numbers. For the seals.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: round 0 rings for wilwoods [Re: moparacer] #1325902
10/26/12 11:21 AM
10/26/12 11:21 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Is Summit the only place to get o-rings and pads? My ft. pads sure look similar to some of the import pads I`ve installed on some cars over the years............
Re: round 0 rings for wilwoods [Re: Thumperdart] #1325903
10/26/12 02:20 PM
10/26/12 02:20 PM
PA
moparacer Offline
moparacer  Offline
PA
Guys I use part number WIL-130-0047 for the dynalites and Summit stocks them.
Re: round 0 rings for wilwoods [Re: moparacer] #1325904
10/26/12 02:29 PM
10/26/12 02:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I assume that`s the pads what about the o-rings........... ?
Re: round 0 rings for wilwoods [Re: Thumperdart] #1325905
10/26/12 02:58 PM
10/26/12 02:58 PM
PA
moparacer Offline
moparacer  Offline
PA
Thats the O rings....
http://www.summitracing.com/parts/WIL-130-0047/
I run Hawk pads on my car.
