round 0 rings for wilwoods
#1325886
10/25/12 12:18 PM
10/25/12 12:18 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I've just put fresh 0 rings in some wilwoods i've just fitted, cleaned all the pistons up and brake cleaned the bores as well but they are still dragging some. I found a thread on classracer.com and they suggested using round seals, instead of the square one from wilwood. Has anyone had a similar problem and these seals cured it and where did you get the seals from ? Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: round 0 rings for wilwoods
[Re: Thumperdart]
#1325891
10/25/12 02:53 PM
10/25/12 02:53 PM
deaks
robin hood country
It must be me then.. The pistons had no marks on them and the seals are new, as are the braided lines from summit. Master cylinder is newer one same as alloy one but the steel version. So i'm all out of ideas. Mick
[Re: deaks]
#1325893
10/25/12 05:27 PM
10/25/12 05:27 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
I thought it was the round ones that "fixed" it. I know I have wilwoods front and rear with their master cylinder and mine drag. If I ever get my motor back I have thought about trying something similar to the stainless wishbone return springs like on ford truck discs.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: Thumperdart]
#1325896
10/25/12 07:16 PM
10/25/12 07:16 PM
deaks
robin hood country
Maybe i should have done that, i used a scotchbrite pad, i didn't think those very faint lines would be a problem. I'm taking the car out this weekend, so i'll leave it for now, i'll probably pull them apart over winter and see what can be done. Mick
[Re: rickraw]
#1325899
10/25/12 08:28 PM
10/25/12 08:28 PM
deaks
robin hood country
Did you buff them with compound Rick ? Mick
