Re: CHRYSLER MP ELECTRONIC DISTRIBUTOR?
[Re: Cab_Burge]
#1325679
10/25/12 04:05 AM
10/25/12 04:05 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I leave the vacume advance pod hook to the pickup plate to keep the plate stabilised You could rivet or bolt the upper and lower plate together also Either way will work
Thats what I was going to say. I have a stock dist in my boys 400 in his Dart and I just left the vacum advance on to keep the plate from moving. If I removed it I would have to secure the plate somehow so it wont move so leaving it on is easy and wont hurt a thing if you dont use it. Ron
[Re: Cab_Burge]
#1325681
10/25/12 06:15 AM
10/25/12 06:15 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Got it in one - without the vac pod attached to the plate, the plate can drift and unwanted timing shifts can occur,
If you want rid of the vac pod, you need to weld the plates.........or buy a "mechanical advance only" race dist.
[Re: Labratt]
#1325682
10/25/12 09:28 AM
10/25/12 09:28 AM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
As said, the arm prevents the upper plate ("breaker plate", though there aren't any breaker points there anymore) from moving even when the advance can isn't operable. If you'd like to eliminate the can for appearance reasons, and still keep the distributor, the easiest way to do it is drill a hole through both the upper and lower plates, then run a screw/nut through both pieces. To keep the two plates square to each other, use a washer/spacer the same thickness as the round nub on the advance arm between the two pieces. Then the pod can be left off, and a little piece fabricated to cover the hole. It's been done before, at least.... I could swear there is a racer with an A body on here who did that but forgot who it was If the plates are welded together instead of the above (which can also work), be careful the ability to change out the pickup in the future isn't lost.....
Rich H.
Esse Quam Videri
