underhood clearance issue #1325446
10/24/12 02:45 PM
10/24/12 02:45 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
i stacked a 1" 4 hole tapered spacer on top of a 1" open and added a air bell on top of carb. this is all on my indy intake. i only have 3/4" clearance between the air bell and the top of scoop on my six pack hood. do you think i will get enough air flow with 3/4" of clearance to feed my 408?
Re: underhood clearance issue [Re: mopar dave] #1325447
10/24/12 02:52 PM
10/24/12 02:52 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
have you ever seen how close the carbs are on a hemi super stocker? its amazing they run as fast as they do
Re: underhood clearance issue [Re: mopar dave] #1325448
10/24/12 02:54 PM
10/24/12 02:54 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Nope. I think you're going to need to remove at least one of those 1" spacers and see how that works.
Re: underhood clearance issue [Re: BradH] #1325449
10/24/12 02:59 PM
10/24/12 02:59 PM
Mt Morris Michigan
Mt Morris Michigan
ok, i'll have to run it without anything on the carb.
Re: underhood clearance issue [Re: mopar dave] #1325450
10/24/12 05:40 PM
10/24/12 05:40 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I put a dominator with adaptor on my car, that was very close to the hood. It took 5mph off the car. It 60ft'd good but layed down after that. Jetted up a couple got 1 mph back, swapped the 950 back on, got the other 4 mph back. All on the same day.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: underhood clearance issue [Re: deaks] #1325451
10/25/12 01:37 AM
10/25/12 01:37 AM
Mt Morris Michigan
Mt Morris Michigan
good info. thanks
