Going from 25" to 22.5" tires frontrunners #1325371
10/24/12 10:13 AM
10/24/12 10:13 AM
mississippi
bentwheel43 Offline OP
mississippi
Hi racers,I am thinking of going from 25"tires with 14x6"rims to 22.5"tires on 15x4"rims. My question is the rake will the car act different.We run 1/8 mile arould 6.40s , a Duster with 511/440 I would hate to buy them thin the steering be way off at the big end.Did anyone do close to this?Its to make more room for headers.Right now I have 29.5x10"on back and 25"x6 with the T-bars set low so it has alot of rake now.If I set the T-bars any higher its all over the bigend and hard to drive.~~ Bentwheel43
Section 8 Racing We are nuts about racing.
Re: Going from 25" to 22.5" tires frontrunners [Re: bentwheel43] #1325372
10/24/12 10:37 AM
10/24/12 10:37 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I really can't say.. Did you have the alinment checked after changing the t-bars ? I went the other way, went from 24in to 27.5 and lowered the t-bars to get the required front end travel I needed and it didn't change the way the car drove at all. 6.20s in the 1/8
Re: Going from 25" to 22.5" tires frontrunners [Re: bentwheel43] #1325373
10/24/12 10:55 AM
10/24/12 10:55 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
C9Thats gonna look goofy. Can you try some Proparts headers?
Re: Going from 25" to 22.5" tires frontrunners [Re: 70dusterjohn] #1325374
10/24/12 02:44 PM
10/24/12 02:44 PM
mississippi
mississippi
I have the moog offset bushings about $53 they helped let me lower the front,it drives good.The small tires mite help on reaction time.Maybe~~~
Re: Going from 25" to 22.5" tires frontrunners [Re: bentwheel43] #1325375
10/24/12 05:10 PM
10/24/12 05:10 PM
It does I treid 135x15 SR on my old Duster when I ran S/ST on the 4 tenths tree years ago, the shorter tires definetly helped
Re: Going from 25" to 22.5" tires frontrunners [Re: Cab_Burge] #1325376
10/25/12 10:39 AM
10/25/12 10:39 AM
mississippi
mississippi
Thanks Cab,I looked it up that 135x15 is 23.62" it mite not look too funny.I saw a (kid) good protree racer useing small GM spare and he was good too!They said the 135x15 works good with 4" rim.
