440 smoking #1325270
10/23/12 11:42 PM
10/23/12 11:42 PM
ca
brownout Offline OP
brownout  Offline OP
ca
Working on a 440 that was built quite a while ago gets run every summer and put away in the winter. It gets started every other month or so and run for a little while. The Car got put away for a couple of months. Fired it up wasn't running right and blowing a lot of smoke out of the exhaust. Number 6 spark plug turned out to have quite a bit of oil on it. What to check first?
Like I said when the car got put away there were no signs of the car burning oil. and now it did not seem to clear up when ran for a maybe 2-3 minutes.
Thanks, Cody
Re: 440 smoking [Re: brownout] #1325271
10/24/12 12:45 AM
10/24/12 12:45 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Probably one of the intake manifold bolts or the intake gasket itself. If the bolts don't have sealer on them, intake vacuum will suck oil past the threads. If you pull the intake manifold and check the ports for oil, it will be pretty obvious if this is your issue. If it's not, you'll probably be pulling a head anyway. Usually a worn valve seal/guide will give a poof of oil smoke on start-up and clean up after that.
Re: 440 smoking [Re: DaytonaTurbo] #1325272
10/24/12 09:26 AM
10/24/12 09:26 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
could be the intake bolt or gasket. If it is the valve seal you can change it while the heads are on. If you pull the intake you'll be able to see if the oil is coming from there.
Coming soon!!!!
Re: 440 smoking [Re: Mr.Yuck] #1325273
10/24/12 09:31 AM
10/24/12 09:31 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
What they said. I have the same issue on my 440. I have been dragging my feet at pulling the intake because I keep telling myself to just wait until I get a six-pack setup and do it once.
Scott
1969 Super Bee, 383/4 speed
Re: 440 smoking [Re: StukaJU87] #1325274
10/24/12 09:45 AM
10/24/12 09:45 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
clean the plug and drive it for a while. The heat might seal up the intake... or you could pull the 2 bolts around 6 and use some sealer and give it a go.
Re: 440 smoking [Re: Mr.Yuck] #1325275
10/24/12 10:50 AM
10/24/12 10:50 AM
PA
BTTG Offline
BTTG  Offline
PA
What is a good sealer to use?
Re: 440 smoking [Re: BTTG] #1325276
10/24/12 01:45 PM
10/24/12 01:45 PM
I use GM thread sealer, availble at your local GM dealers Or you can use ARP thread sealer, your choice
Re: 440 smoking [Re: Cab_Burge] #1325277
10/24/12 02:16 PM
10/24/12 02:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
don't use too much, squeeze a dab on then run it up the bolt. Wipe any excess off. It the bolt comes out dripping w/ oil that might be your problem.
Re: 440 smoking [Re: Mr.Yuck] #1325278
10/24/12 02:42 PM
10/24/12 02:42 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The bolts that hold the intake to the heads do not go into the intake runners, ports, combustion chamber, or any intake vacuum source. They go into the open area in the head near the push rod passages. Heck if the threads for the intake bolts strip you can actually put a lock nut on the inside of the head passage to tighten the intake down. Oil creeping up the bolt threads ends up pooling in the valley pan under the intake, not burning in the cylinder and creating exhaust smoke. Could likely be cracked/broken valves stem seals allowing oil to seep down the guide and pooling on the valve causing smoke on start up. .
Re: 440 smoking [Re: MoparforLife] #1325279
10/24/12 11:49 PM
10/24/12 11:49 PM
ca
brownout Offline OP
brownout  Offline OP
ca
I am leaning towards a valve seal but it smokes a lot and didnt seem to clean up at all. The motor has never smoked before so it seems hard to believe that it is suddenly from the intake bolts not having sealer but I will let you know what I find. Thanks for giving me a place to start.
Cody
Re: 440 smoking [Re: brownout] #1325280
10/24/12 11:58 PM
10/24/12 11:58 PM
R&R the valley pan & use some sealer lightly/evenly around both sides of the 8 valley pan port openings
Re: 440 smoking [Re: RapidRobert] #1325281
10/25/12 12:15 AM
10/25/12 12:15 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Are you running the composite gaskets on either side of the valley pan? I know of some that just use the tin pan with some sealer and it's possible that it's leaking to the #6 intake port. May want to invest in an intake gasket set and the valley pan. That way you can check the port and also reseal the intake.
Re: 440 smoking [Re: dodgeboy11] #1325282
10/25/12 02:19 AM
10/25/12 02:19 AM
ca
brownout Offline OP
brownout  Offline OP
ca
yea its just the tin bathtub gasket. They seem to be fine on other motors. Tomorrow I should have time to inspect some of the valve seals.
Cody
Re: 440 smoking [Re: brownout] #1325283
10/25/12 07:50 AM
10/25/12 07:50 AM
Upper Midwest
Upper Midwest
Cody
Like I said - intake bolts can't seep oil into the combustion chamber.
