Re: 1970 Road Runner trunk and quarter replacement
[Re: Jimster70]
#1325233
02/26/13 05:07 PM
02/26/13 05:07 PM
Posts: 1,064 Newton, KS
70B5Cuda
Newton, KS
Thanks for the info-I just ordered a set from the same link! I did it the hard way 2 years ago with my 70 Barracuda. I spent HOURS and HOURS grinding through each weld...never again thanks to you! Dod you have an estimate of how long it took you to cut all the trunk floor welds and remove the trunk pan?
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: Jimster70]
#1325234
02/26/13 09:42 PM
02/26/13 09:42 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
Looking good. I am just beginning the tear down of my 68 Road Runner. The driver's side was hit hard and repaired with a sledge hammer and a couple of gallons of bondo. I have had to remove the inner structure and door jamb. I am onto the trunk in the next few weeks.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Jimster70]
#1325242
02/27/13 02:59 PM
02/27/13 02:59 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Now what to do with this sunroof? Volvo swap or plug it? I am on the fence about this roof
Pencil me in for 'plug it'...
[Re: Jimster70]
#1325246
02/28/13 01:02 AM
02/28/13 01:02 AM
Posts: 4,872 connecticut
pnypwr
connecticut
when its metal your not gonna use i tend to take the air chisel to the spot welds...you wont did into the rail...saves a ton of time over drilling the welds. if you plan on reusing a panel a 1/2 roto is humongas and your just filling and filling for reuse i like 3/8 but fresh metal ill drill a 1/4 in hole to plug weld. i need to get back on my 68, your cars alot more solid than mine however, i woulda loved to get away with cheater skins.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: Jimster70]
#1325248
02/28/13 02:30 PM
02/28/13 02:30 PM
Posts: 1,377 Back In Iowa
belv2vert66
Back In Iowa
rr4
Awesome work ! Just out of curiousity .....Does anyone know if you can split the full trunk floor right over where the frame rail is and have it still fit through the trunk opening ? It would save having to "finish" the bottom of the trunk floor as the frame rail would hide it
