Re: 4 speeds and thrust bearings
[Re: The Sphinx]
#1325100
10/23/12 07:46 PM
10/23/12 07:46 PM
Posts: 1,505 TN
SCATPACK 1
TN
I have ran one for 40 years and never noticed any difference in wear. I suppose if the crank were rough or if there was some foreign matter in the oil, it could have more effect with the added pressure from the clutch being pushed in. But never had n issue with any of mine.
Old Geezer Racing
[Re: The Sphinx]
#1325102
10/24/12 02:58 AM
10/24/12 02:58 AM
Posts: 43,290 Bend,OR USA
Cab_Burge
[Re: HPMike]
#1325103
10/27/12 11:06 PM
10/27/12 11:06 PM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
I've never really noticed anything of consequence. But I do think its a good idea to jump out(disable) the clutch start switch so you dont have to push the pedal in to get the car started.
MB
I was told by my engine builder to always start the car in neutral with the clutch pedal out, sounded good to me.
Also, I just went through getting my engine rebuilt because the thrust bearing (among other things) was shot. I also found that there may have been a problem of my pilot bearing bearing a touch too tight on my input shaft.
[Re: Evil Spirit]
#1325105
10/28/12 09:56 AM
10/28/12 09:56 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
And someone that rebuilds starters would tell you to shove the clutch in to reduce drag from the trans trying to spin the countershaft in the gear oil
Maybe, but unless you are trying to start the car in the Antarctic, there really isnt that much effort required to turn an input/counter shaft in gear oil. Its supported by bearings.
MB
[Re: Evil Spirit]
#1325107
10/28/12 11:44 AM
10/28/12 11:44 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
MB
It isn't the drag from the bearings - it's the drag from turning the countershaft submersed in gear oil.
The reason behind the myth to start in neutral with the clutch out is to protect a dry thrust bearing. Really? Pull apart an engine thats been sitting for 10 years and there will still be an oil film on the bearings. If the oil would completely drip off the crank, it would also drip off the cam, which is much higher loaded - flat tappet cams survive thousands of dry starts quite well. Why? Because even if the visible oil drips off there is still a film that protects the surface from wear. And since oil doesn't evaporate, there is plenty left on/in thrust bearings etc. for cold starts.
I never said it was the drag from the bearings-not sure how you extracted that from my comment...
The bearings help negate any so called "drag"...Grab an input shaft of an 833 filled with gear oil and turn it with your hand. I've never actually tried it, but the turning torque required to turn that input shaft likely couldn't even be measured with an in/lb torque wrench. Its a total non issue.
I'm not saying if you step on the clutch while starting you will wipe out your thrust bearing, but many other individuals that have great experience also believe its good practice to not do it.
I also wouldn't dare start a race engine that has been sitting for a year(let alone 10 years) without pre lubing it first. I guess I just prefer to err on the side of caution...
MB
[Re: HPMike]
#1325108
10/28/12 01:02 PM
10/28/12 01:02 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
MB
MB
You said their wasn't that much drag, because it was supported by bearings - that's where I extracted it from your comment. Big difference in the amount of drag from trying to slowly turn the input with your hand and spin it a couple hundred cranking RPM. Many people do things, like start cars with the clutch out, because they heard of a guy that met a guy whose uncle did this and he heard you should do it that way. In other words, until someone can use LOGIC and explain to me how that thrust bearing can go bone dry from sitting a short time and cause damage from no lube while being started with the clutch being pushed in - I'll call that MYTH B/S. And I never said to start a 10 yr old engine - just that there would be oil still in the bearings.
Free advice and worth every penny... Factory trained Slinky rewinder.........
