Re: when to upgrade from an 8 3/4?
[Re: old_racer]
#1324945
10/23/12 02:49 PM
10/23/12 02:49 PM
Posts: 528 Oak Grove, MN
lowflyingdart
Oak Grove, MN
It is cheaper to change now than to throw away money on an 8 3/4". Do not put your customer, his oppenets and the track officials in danger by putting an explosive combination together. At 11.90 ETs an 8 3/4" ring and pinion needs to be replaced every 100 passes. In the long run it will be cheaper to runa a Dana 60.
"I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
[Re: lowflyingdart]
#1324947
10/23/12 03:11 PM
10/23/12 03:11 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
Huh, I guess my 8 3/4 didn't get that memo. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: CrAzYMoPaRGuY]
#1324949
10/23/12 03:28 PM
10/23/12 03:28 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
![](/ubbthreads/images/graemlins/laugh2.gif) I was gonna say the same thing!!!! My 63 Dodge had hundreds and hundreds of passes with a best of 11.63, never even looked INTO the diff! ![](/ubbthreads/images/graemlins/eeek.gif)
My 1963 Plymouth M.W. stocker got hundreds of runs on the original 4.56 OEM gears, they never broke Most after market gears are not so good OP, as already said, how lucky are you feeling?
[Re: Thumperdart]
#1324951
10/23/12 04:24 PM
10/23/12 04:24 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Same here... For now Bottom Tens, 3200 lb car and no special mods, Just axles. I can't badmouth an 8 3/4 but I do plan to replace it this winter with a Dana ![](/ubbthreads/images/graemlins/luck.gif)
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: dirt]
#1324952
10/23/12 04:37 PM
10/23/12 04:37 PM
Posts: 4,213 New York
polyspheric
New York
It's only worth money to someone else while it's still in good shape. After it breaks it costs you money either way.
Boffin Emeritus
[Re: gregsdart]
#1324957
10/23/12 06:39 PM
10/23/12 06:39 PM
Posts: 3,210 robin hood country
deaks
robin hood country
If you look in the parts section of this site, you will see someone has just posted a dana 60 with a spool and 35 spline shafts for $500 in NJ Mick ![](/ubbthreads/images/graemlins/thumbs.gif)
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: gregsdart]
#1324958
10/23/12 06:40 PM
10/23/12 06:40 PM
Posts: 20,938 A collage of whims
topside
A collage of whims
I gave the 8.75-vs-Dana60 choice a lot of thought on my wagon project, and the difference was only about $200 between narrowing & bracing an 8.75, axles, diff housing, caps, SureGrip, bearings, & gears vs a Dana with new good axles, SG, bearings, & gears. The car's just a footbrake BB deal, but with 3700-3800 lbs & slicks, I figure that's money well spent. I have enough things to worry about already. As a kind of bonus, that A-body rearend is pretty valuable, judging by the last time I needed one.
[Re: rickraw]
#1324961
10/23/12 09:41 PM
10/23/12 09:41 PM
Posts: 437 south central pa
bdaz smblk
south central pa
I've been 9.0's 150 at 3,200 with a 8 3/4 with 1.20 couple 60 ft.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
