Starting issue with dumptruck
#1324891
10/23/12 12:51 PM
10/23/12 12:51 PM
Posts: 2,514 PA
moparacer
PA
My friend had a 1976 Dodge D600 dump truck with a 360 in it that wont start with the ignition switch. You can drift start it and it fires right up. He tried changing the ballast resistor and it didn't fix it.
Also says that when you are cranking it over and let off the switch it will try to fire sometimes.
Anyone have any ideas what else could be wrong?
Thanks!
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Starting issue with dumptruck
[Re: moparacer]
#1324892
10/23/12 01:11 PM
10/23/12 01:11 PM
RapidRobert
Take off the yellow "ign" wire from the starter relay to disable the starter so as to not run the batt down & no need for the starter noise distraction then have a helper hold the key to "start" & you under the hood & see if the ballast/coil/ECU are recieving fire. Assuming 4 terminal ballast/5 pin ECU. 2 pins of the ECU need fire in "start" as does the coil positive primary terminal. What is drift starting? I'm assuming that is push starting it with the key in "on" rather than in "start" which points to an ign2 (cranking) circuit open
[Re: moparacer]
#1324894
10/23/12 02:46 PM
10/23/12 02:46 PM
Posts: 4,848 Memphis
HemiRick
Memphis
The ign switch is not providing power to the ign during crank, it needs an ign switch or a bad connection.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: dogdays]
#1324896
10/23/12 06:34 PM
10/23/12 06:34 PM
Posts: 2,514 PA
moparacer
PA
He replaced the ignition switch already. Going to have him check the wire.
[Re: moparacer]
#1324897
10/23/12 09:07 PM
10/23/12 09:07 PM
RapidRobert
see if the ign2 (crank) wire is hot at the bulkhead (both sides) when the key is held to "start". This'll tell him whether to work downstream toward the coil/ECU or back toward the ign switch for the open
[Re: RapidRobert]
#1324898
10/24/12 11:19 PM
10/24/12 11:19 PM
Posts: 2,525 God's Country Maryland
GODSCOUNTRY340
Check the fuse box in the glove box. These were notorious for melting the plastic around the fuses and losing contact.
