Ron's terminator throttle stop #1324701
10/22/12 11:41 PM
10/22/12 11:41 PM
oroville, ca
tonys68dart Offline OP
oroville, ca
I've got a Ron's terminator injection and was looking for some input as to what throttle stop works best and what if any changes need to be done. Ron's website recommends K&R,but if there are any other options, I would like to hear what you guys are using,thanks
Re: Ron's terminator throttle stop [Re: tonys68dart] #1324702
10/23/12 10:53 AM
10/23/12 10:53 AM
ok
mopdragster Offline
mopdragster  Offline
ok
I ran the biondo air on-air off inline linkage stop for years on a terminator. Had very good sucess was consistent and we went rounds every divisional and national we went to. Best advice I got was to go out at least .5 on timer 1 to burn off the extra fuel from being up on the 2 step before going on the stop. Used to run 2500 stop rpm so you basically shut it all the way down so it will bypass fuel properly.
Re: Ron's terminator throttle stop [Re: mopdragster] #1324703
10/23/12 01:03 PM
10/23/12 01:03 PM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
I use the Biondo in-line co2 one as well. Works great! I come on the stop at .08 and was very consistant but after doing more research, I should be waiting between 0.5-0.8 before getting on the stop. Still learning! Good luck with your choice
Re: Ron's terminator throttle stop [Re: Gearhead383] #1324704
10/23/12 02:35 PM
10/23/12 02:35 PM
oroville, ca
oroville, ca
Awesome,thanks for the input! Were you guys running a 727 or glide with those increments? Thanks again
Re: Ron's terminator throttle stop [Re: tonys68dart] #1324705
10/23/12 03:05 PM
10/23/12 03:05 PM
ok
mopdragster Offline
mopdragster  Offline
ok
GLIDE
Re: Ron's terminator throttle stop [Re: mopdragster] #1324706
10/24/12 08:21 AM
10/24/12 08:21 AM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
Glide
