B Body 4 speed pedals #1324695
10/22/12 11:07 PM
10/22/12 11:07 PM
Mid Michigan
Coronet-R/T-Rag Offline OP
Mid Michigan
I'm going to swap the 727 for a 4 speed in my 67 Coronet. I need to get a set of 4 speed pedals. Are the pedals the same 66 - 70 or do I have to use 66-67 pedals. I know the 66-67 are different but will the 68-70 work????
Thanks Moparts!
Re: B Body 4 speed pedals [Re: Coronet-R/T-Rag] #1324696
10/22/12 11:12 PM
10/22/12 11:12 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
You can use the 68-70 pedals but....the area where the hvac hoses goes thru in different on the 68-70. Therefore if you don't care about hvac you are fine.
Re: B Body 4 speed pedals [Re: moparpollack] #1324697
10/23/12 10:39 AM
10/23/12 10:39 AM
Mid Michigan
Mid Michigan
Are we talking ac / heater hoses to engine or defrost hose from heater box or what? Thanks.
Re: B Body 4 speed pedals [Re: Coronet-R/T-Rag] #1324698
10/23/12 12:00 PM
10/23/12 12:00 PM
85086
Lil Herman
Lil Herman
85086
The Defrost flexible hoses under the dash.
Re: B Body 4 speed pedals [Re: moparpollack] #1324699
10/23/12 12:29 PM
10/23/12 12:29 PM
Mid Michigan
Mid Michigan
Thanks for the input.
