ignition system.. #1324400
10/22/12 03:41 PM
10/22/12 03:41 PM
california u.s.a.
racecar43 Offline OP
california u.s.a.
When using mopar electronic ignition do you use the ballast resistor?
Re: ignition system.. [Re: racecar43] #1324401
10/22/12 03:58 PM
10/22/12 03:58 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yes
Re: ignition system.. [Re: MoparforLife] #1324402
10/22/12 04:04 PM
10/22/12 04:04 PM
california u.s.a.
california u.s.a.
Thx.....and does the box takes 12 volts? or does it go through the resistor also ?
Re: ignition system.. [Re: racecar43] #1324403
10/22/12 06:20 PM
10/22/12 06:20 PM
Upper Midwest
Upper Midwest
Re: ignition system.. [Re: racecar43] #1324404
10/22/12 07:32 PM
10/22/12 07:32 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
A couple of things to keep in mind..
1. Depends upon brand/model coil is used
2. The ohms value of the ballast resistor will vary depending upon brand/model coil
Just my $0.02...
Re: ignition system.. [Re: racecar43] #1324405
10/22/12 09:10 PM
10/22/12 09:10 PM
More info please. What year/make/engine. 2 or 4 terminal ballast? What coil? (ohms) & OE or aftermarket. 4 or 5 pin ECU? Stock or aftermarket ECU.
