That Sweet Sound! #1324252
10/22/12 03:27 AM
10/22/12 03:27 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Well I finally decided to start the 572 hemi I have spent the last 2 years building. Its been sitting for 3 months waiting for the body so I got impatient....went to the local salvage yard to get a /6 electronic ignition harness, grabbed an old orange box and 4 hours later she was running.
I wound up sticking the gas line into an old jerry can, borrowing the battery out of my hot rod Kia and cranked her over on the cradle I built.
NOTE TO SELF: make sure use the correct rotation when installing plug wires...she did run on 1 cylinder but it was pretty anemic...
ANOTHER NOTE TO SELF: dont point the headers into the shop on a fresh engine, the smoke was pretty bad for the initial start up.
With a little tuning and the correct firing order she was the loudest engine I have ever built....
GAWD damn a hemi is a beautiful thing. Now I just need a car to put it in.
Re: That Sweet Sound! [Re: astjp2] #1324253
10/22/12 03:40 AM
10/22/12 03:40 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
So now I have to figure out how to fix the leaks I found. Rear main is spewing and the racepumps 2000 has a leak and the fuel pump push rod is hammering pretty bad.
The world block came with a billet rear seal retainer, I had a hell of a time getting the side seals down, I may look for an original cast one and see if it works better.
So my big question is....is 70 PSI too much? I am running a HV oil pump and 3/4" line from the Milidon 31581 external pickup to the front of the block.
Tim
Re: That Sweet Sound! [Re: astjp2] #1324254
10/22/12 12:09 PM
10/22/12 12:09 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
I have never had luck with the billet ones. I use stock cast seal retainers in all of my builds, with superperformance gaskets.
How heavy is the oil? I run 15-40 in my junk and its usually about 80-90 cold and drops to 60 after a few minutes. If it gets really hot (I have a diaper and it retains heat) it may go down to 40-50 when we hot lap. This is all at idle, of course. The bypass is set around 90, which is where it stays down track. Don't want it going over that because I've had it blow a filter apart. I think the splatter reached a bush 15 feet away.
As far as the oil pump push rod, make sure its getting oil. You should have a small (i forget the dimension) hole in one of the galley plugs to spray the chain and the pump eccentric/push rod. The push rod may be binding.
Re: That Sweet Sound! [Re: Kevins493] #1324255
10/22/12 12:38 PM
10/22/12 12:38 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Its a brass tipped one from comp cams, the Racepumps pump almost sounds like a lifter tapping and I could hear it over the open headers. Tim
Re: That Sweet Sound! [Re: astjp2] #1324256
10/22/12 12:38 PM
10/22/12 12:38 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Tim there was an old blog (maybe a year ago) on here about the World blocks rear seal not lining up with the block seal. By chance did you think to double check that? I don't know how you could check it with the crank in it, but the pictures in the old article were pretty clear of the misalignment when the crank was not there. I really hope that is not your problem.
Old Geezer Racing
Re: That Sweet Sound! [Re: SCATPACK 1] #1324257
10/22/12 12:39 PM
10/22/12 12:39 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I thought I checked it, but I put it together in april so I am fuzzy on everything I checked. If not I will have to find an original and try that. Tim
Re: That Sweet Sound! [Re: astjp2] #1324258
10/22/12 02:17 PM
10/22/12 02:17 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Glad to hear you got her fired up. I bought my rear main seal and retainer from Hughes. I can only imagine how big a smile it must have put on your face. Ron
Re: That Sweet Sound! [Re: 383man] #1324259
10/22/12 02:39 PM
10/22/12 02:39 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
congrats on firing that big hemi:)
Re: That Sweet Sound! [Re: Kevins493] #1324260
10/22/12 02:44 PM
10/22/12 02:44 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I think I put in 5w50 castrol syntec, with the roller cam I was not too concerned about breaking in the cam, but the rings need a good 50 hours of run time before they get a good seal. It was neat to hit the starter button and have it fire right off, no hesitation at all, about half a crank revolution and she was running. Tim
Re: That Sweet Sound! [Re: astjp2] #1324261
10/22/12 08:56 PM
10/22/12 08:56 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
What is a good way to break in a roller motor to seat the rings? I am running on just a stand so no driving yet...Tim
Re: That Sweet Sound! [Re: astjp2] #1324262
10/22/12 11:24 PM
10/22/12 11:24 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
on a dyno or in the car. gotta put a load on the motor to seat the rings. think WOT in high gear.
WOT with no load on the engine just moves the parts faster without building any real cylinder pressures, and it's the cylinder pressure that you need to push the rings out against the bore to get them to seat.
a few minutes run time to break in a cam, bring it to temp to check for leaks, etc. won't hurt anything, but don't run it again until you can put a load on it!
**Photobucket sucks**
Re: That Sweet Sound! [Re: 70Cuda383] #1324263
10/23/12 03:20 AM
10/23/12 03:20 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Well I am going to work on leaks next, I need to contact racepumps to find out about the pushrod length, I could hear it tapping over the open headers...Tim
Race pumps fuel pump [Re: astjp2] #1324264
10/24/12 02:31 AM
10/24/12 02:31 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Has anyone used a racepumps fuel pump before? What did you use for a pushrod? How did you keep it from leaking. Tim
