HURST Shifter ??? #1323686
10/21/12 02:57 AM
10/21/12 02:57 AM
Kent, Wa
340SHORTY Offline OP
Truck Nut
Truck Nut
Kent, Wa
A friend of mine gave me a new Comp + shifter. It is the bolt on version. The stock shifter in my Shorty works good but is a tad sloppy. How hard would it be to put the shifter pop in part into the new Comp + mechanism??
I am truckless..
Re: HURST Shifter ??? [Re: 340SHORTY] #1323687
10/21/12 09:14 PM
10/21/12 09:14 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
So you prefer the sloppy push-in version to the bolt-on handle
You can swap them but I don't see why you would want the loose push in deal.
Gus
64 Plymouth Savoy
Dana 60
Re: HURST Shifter ??? [Re: fourgearsavoy] #1323688
10/21/12 09:25 PM
10/21/12 09:25 PM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
I suppose I could drill my Pistol Grip handle to fit the comp + unit..
I am truckless..
Re: HURST Shifter ??? [Re: 340SHORTY] #1323689
10/21/12 09:39 PM
10/21/12 09:39 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Bolt in is superior for sure.
Sheldon
