verta ??? for big block
#1323634
10/20/12 11:29 PM
10/20/12 11:29 PM
Posts: 2,449 nc
earthmover
nc
ok guys i will b putting my motor in the duster this week i hope so i have a few ??? on the verta.. i have 2 verta 1 is a 8" turbo action 5600 and the other is a 9.5 dynamic 5000 my motor is 451 (low deck) -1 heads cam motion solid roller 727 tran gear i think will be 4.56 tire 18.5/31 73 duster tube chassis car hope to be about 2500 total weight what verta should i run???? anymore info needed let me know i think i got most of it ... thanks
Re: verta ??? for big block
[Re: rebel]
#1323636
10/21/12 09:25 AM
10/21/12 09:25 AM
Posts: 2,449 nc
earthmover
nc
cam info 111.9 lobe seperation valve overlao 55.3 intake centerline 107.9 atdc valve close 64.4 abcd valve open 28.8 btdc dur. 273.3 lobe lift .46051 in valve lift .69077 in lobe area 40.9 in deg exhaust valve open 76.2 bbdc centerline 115.9 btdc valve close 26.5 atdc dura 282.7 lobe lift .44102 in valve lift .66154 in lobe area 41.28 valve lash 23/23
[Re: earthmover]
#1323637
10/21/12 06:13 PM
10/21/12 06:13 PM
Posts: 4,647 aotearoa
rebel
aotearoa
your cam ain't that different from mine, just your car is lighter with less rear gear than i'm running. my cam is 272/279@050 with 660 lift. rear gears are 4.88, car weighs 2950 with my fat butt in the chair, slicks are 32x14 MT's, i launch @ 4400 on the brake & i usually run 1.3x 60's, 6.0@112mph half track, 9.42@142 1/4's. i'm still using a 4150 demon 1025cfm carb which probably could be bigger. i would go with the TA verter, it'll have you right in your power band every change. but thats just my
[Re: earthmover]
#1323638
10/21/12 06:59 PM
10/21/12 06:59 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
[Re: rebel]
#1323639
10/21/12 07:34 PM
10/21/12 07:34 PM
Posts: 2,449 nc
earthmover
nc
your cam ain't that different from mine, just your car is lighter with less rear gear than i'm running. my cam is 272/279@050 with 660 lift. rear gears are 4.88, car weighs 2950 with my fat butt in the chair, slicks are 32x14 MT's, i launch @ 4400 on the brake & i usually run 1.3x 60's, [Email]6.0@112mph[/Email] half track, [Email]9.42@142[/Email] 1/4's. i'm still using a 4150 demon 1025cfm carb which probably could be bigger. i would go with the TA verter, it'll have you right in your power band every change. but thats just my
woo 4.88 man everyone says the 4.56 would do me well...i am new to big block so
[Re: earthmover]
#1323640
10/21/12 09:27 PM
10/21/12 09:27 PM
rebel
aotearoa
4.56's are probably ok too, i tend to holeshot most of my competition, i put that down to the 4.88's.
[Re: rebel]
#1323641
10/21/12 09:49 PM
10/21/12 09:49 PM
Posts: 2,449 nc
earthmover
nc
