verta ??? for big block #1323634
10/20/12 11:29 PM
10/20/12 11:29 PM
nc
E
earthmover Offline OP
E
nc
ok guys i will b putting my motor in the duster this week i hope so i have a few ??? on the verta..
i have 2 verta 1 is a 8" turbo action 5600 and the other is a 9.5 dynamic 5000
my motor is
451 (low deck)
-1 heads
cam motion solid roller
727 tran
gear i think will be 4.56
tire 18.5/31
73 duster tube chassis car
hope to be about 2500 total weight
what verta should i run????
anymore info needed let me know i think i got most of it ... thanks
Re: verta ??? for big block [Re: earthmover] #1323635
10/21/12 01:50 AM
10/21/12 01:50 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i think i have the same 8" TA verta as you. great piece, i've been using mine for years with a few different combos. do you have your cam specs as that will be a deciding factor on which to use? that 8" verter of mine i've run with cams 270+ @ 050, wouldn't want to be running with a tamer cam thats for sure.
Re: verta ??? for big block [Re: rebel] #1323636
10/21/12 09:25 AM
10/21/12 09:25 AM
nc
E
E
nc
cam info
111.9 lobe seperation
valve overlao 55.3
intake
centerline 107.9 atdc
valve close 64.4 abcd
valve open 28.8 btdc
dur. 273.3
lobe lift .46051 in
valve lift .69077 in
lobe area 40.9 in deg
exhaust
valve open 76.2 bbdc
centerline 115.9 btdc
valve close 26.5 atdc
dura 282.7
lobe lift .44102 in
valve lift .66154 in
lobe area 41.28
valve lash 23/23
Re: verta ??? for big block [Re: earthmover] #1323637
10/21/12 06:13 PM
10/21/12 06:13 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
your cam ain't that different from mine, just your car is lighter with less rear gear than i'm running.
my cam is 272/279@050 with 660 lift. rear gears are 4.88, car weighs 2950 with my fat butt in the chair, slicks are 32x14 MT's, i launch @ 4400 on the brake & i usually run 1.3x 60's, 6.0@112mph half track, 9.42@142 1/4's. i'm still using a 4150 demon 1025cfm carb which probably could be bigger.
i would go with the TA verter, it'll have you right in your power band every change. but thats just my
Re: verta ??? for big block [Re: earthmover] #1323638
10/21/12 06:59 PM
10/21/12 06:59 PM
I would put the T/A in it to start with, if you want to test the other one later you'll have a base line to start with. T/A 8 inch race converters flat ROCK
Re: verta ??? for big block [Re: rebel] #1323639
10/21/12 07:34 PM
10/21/12 07:34 PM
nc
E
E
nc
my cam is 272/279@050 with 660 lift. rear gears are 4.88, car weighs 2950 with my fat butt in the chair, slicks are 32x14 MT's, i launch @ 4400 on the brake & i usually run 1.3x 60's, [Email]6.0@112mph[/Email] half track, [Email]9.42@142[/Email] 1/4's. i'm still using a 4150 demon 1025cfm carb which probably could be bigger.
woo 4.88 man everyone says the 4.56 would do me well...i am new to big block so
Re: verta ??? for big block [Re: earthmover] #1323640
10/21/12 09:27 PM
10/21/12 09:27 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
4.56's are probably ok too, i tend to holeshot most of my competition, i put that down to the 4.88's.
Re: verta ??? for big block [Re: rebel] #1323641
10/21/12 09:49 PM
10/21/12 09:49 PM
nc
E
E
nc
Re: verta ??? for big block [Re: earthmover] #1323642
10/22/12 01:09 AM
10/22/12 01:09 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
