Converter spacing #1323302
10/20/12 01:15 PM
10/20/12 01:15 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
If I took a stright edge and layed it across the bell housing section of
a 727 transmission what is the distance between the torque converter and the
stright edge?
Also can I grind down the hight of the feet of the converter for a little
binding releaf?
Re: Converter spacing [Re: JoWeTu_6] #1323303
10/20/12 02:10 PM
10/20/12 02:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know off hand but if you measure the distance
of the flex plate from the back of the block and the
distance of the conv back behind the front of the
bell you should come up with about 1/4" of gap
Re: Converter spacing [Re: MR_P_BODY] #1323304
10/20/12 02:26 PM
10/20/12 02:26 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
The thing is I just recived my converter from Lenny, and it's tight im thinking I need to trim down the feet but I dont know if it's ok to do that is it.
Thanx.
Re: Converter spacing [Re: JoWeTu_6] #1323305
10/20/12 02:29 PM
10/20/12 02:29 PM
Az
Crizila Offline
Crizila  Offline
Az
With the convertor pushed all the way in to the pump, you should have at least 1/4" clearance between the convertor lugs and the flexplate. You should have to pull the convertor back out to make contact with the vlexplate. If no clearance there, you have a problem somewhere. Start by making sure the convertor is fulley seated in to the pump notches. Still no clearance, it's gotta come apart, cause there is a part mismatch somewhere.
Fastest 300
Re: Converter spacing [Re: JoWeTu_6] #1323306
10/20/12 02:32 PM
10/20/12 02:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would make sure it dropped all the way in on the
input(3 drops)
Re: Converter spacing [Re: MR_P_BODY] #1323307
10/20/12 02:50 PM
10/20/12 02:50 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Ooooooh I thought it was 2 drops, I will go check it rt know and let you all know how it comes out but I will say this I realy thik it's all the way in.
Re: Converter spacing [Re: JoWeTu_6] #1323308
10/20/12 03:06 PM
10/20/12 03:06 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The third drop can sometimes be a real pain to get.
You don't have it in the car already do you? If it's not on the third drop you'll have it wedged on the pump gears.
Re: Converter spacing [Re: JoWeTu_6] #1323309
10/20/12 03:18 PM
10/20/12 03:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The distance between the bellhousing face and the converter drive lugs should be at least 1/2".
If, for some reason, you do need to thin the drive lugs I wouldn't do it any way but in a lathe to be sure they're square and equidistant.
Re: Converter spacing [Re: John_Kunkel] #1323310
10/20/12 03:39 PM
10/20/12 03:39 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
OMG I can not beleave this the converter center is even wit the bell end of the trans so I need to find that third drop, the trans is not in the car but Iv'e been fighting this thing sence lads night.
Re: Converter spacing [Re: JoWeTu_6] #1323311
10/20/12 04:42 PM
10/20/12 04:42 PM
Franklin Furnace, OH
moparman1954 Offline
Dont trim anything. Its just not in all the way. Sometimes they are a real pain, but keep trying. Sooner or later it'l drop right in.
Re: Converter spacing [Re: moparman1954] #1323312
10/20/12 05:04 PM
10/20/12 05:04 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Well after carefull pushing and a bit of measuring and examing with the flash light I noticed nicks on the pump shaft, the torque conv. will not go all the way down because the splines dont go down any further, ergo this converter is set up for an aluminum mid plate not my 1/8 steel plate.
Thats my conclusison so I'm faced with send it back make a spacer plate or shade tree it and use washers between the trans and the block.
Anyone with any ideas?
Re: Converter spacing [Re: JoWeTu_6] #1323313
10/20/12 06:04 PM
10/20/12 06:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is a 727 correct... if so I'll measure the
distance on the snout and the pads on one of my stock
type conv to see if that is your issue... unless
someone already knows those numbers
EDIT
Because if it is set up for a alum mid plate the
snout will be longer as well as the pads
Re: Converter spacing [Re: JoWeTu_6] #1323314
10/20/12 06:11 PM
10/20/12 06:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Also if you are using a 1/8" mid plate I would have
it set up for that.... I run .090 mid plates and I can
use the stock conv distances but with .125 it pulls
the conv out to far (in my opinion)so the pump rides
on a small area.... so in your case I would send it
back and have it adjusted for the .125 plate
Re: Converter spacing [Re: MR_P_BODY] #1323315
10/21/12 12:43 PM
10/21/12 12:43 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Well hear is what I have. I put some putty between the conv and the trans and I got .165 squish. Hear is a pic of the gap between the trans and the end of the conv, the other is of the nicks on the pump shaft.
I may have a bad conv, I hope not delays are killing me and @ $1200 it cant be.
Re: Converter spacing [Re: JoWeTu_6] #1323316
10/28/12 09:58 AM
10/28/12 09:58 AM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Well after carfull measuring a lot of thought and a long conversation with Lenny the concluision is the internals will have to be adjusted.
With that said I sent the converter back to Lenny saturday.
Updates to come.
Re: Converter spacing [Re: Crizila] #1323317
10/28/12 11:41 AM
10/28/12 11:41 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
You might get away with 1/4" clearance with a 727 and their stronger converter hubs, but if you can pull a 904 converter forward 1/4" you are pretty much guaranteed to break the punp drive ears off the converter stub. I shoot for .060 and shim at .090 - if you can pull the converter farther out than that you are running the pump gear lugs too far out in the converter drive stub slots, weakening it severely.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Converter spacing [Re: Evil Spirit] #1323318
10/29/12 08:56 AM
10/29/12 08:56 AM
NC USA
U
ultimatelenny Offline
U
NC USA
I have been in contact with the owner going over the spacing issue and it will be rectified. As far as overall heights on the 727 converter, the overall height is between 5.400 (low side) and 5.475 (high side). I try to stack all our 727's at 5.400 to be safe with all the aftermarket clearances and the fact that the Chryslers are all very limited for space. This customers converter was built for use with a 1/8" mid plate, therefore the overall height is 5.525-.550. This application is going behind an aftermarket alum. block and crank and the spacing can be varied, but the thing that has me scratching my head are the marks on the stator support , which I will correct as well as giving him the spacing it needs (.125)
Lenny Croteau www.ultimateconverter.com Phone 704-892-6837 Fax 704-892-6880
