Re: Take a look at these spark plugs
[Re: MidPenMopar]
#1322985
10/19/12 10:41 PM
10/19/12 10:41 PM
Posts: 300 St.Louis ,Mo.
72sat
St.Louis ,Mo.
you have a very seareous oil problem. does it smoke all the time?; or just at state up.
[Re: MidPenMopar]
#1322986
10/19/12 10:44 PM
10/19/12 10:44 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Do you have any other pics, different angles etc?
CrAzYMoPaRGuY
[Re: 72sat]
#1322987
10/19/12 11:18 PM
10/19/12 11:18 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Hummmmn no real smoke at start up and no real bad oil usage. If you stomp on it there will be some out the pipes but not anything terrible.
This is the original engine to the car so it's 43 years old.
Oh and i have been running 100 octane as well as Seafoam gas treatment if that means anything??
[Re: d-150]
#1322989
10/19/12 11:30 PM
10/19/12 11:30 PM
MidPenMopar
maybe seafoam is cleaning up pistons and valves and it is sticking to your spark plugs?
Interesting observation as in the past on start up the engine always a little upper end ticking for a few minutes untill it warmed up and now that you mention it the ticking is gone.
[Re: MidPenMopar]
#1322992
10/20/12 02:30 AM
10/20/12 02:30 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Well at 43 years old the valve seals are either gone / rock hard or
Next get a decent compression gauge and go to town and right down the #s
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: MidPenMopar]
#1322994
10/20/12 11:19 AM
10/20/12 11:19 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Does that plug look 1/8" too short is that just me! Put a set of RJ12YC's in and try tha! I'm pretty sure that you have the wrong plugs I think what you are using are for a 1941 ford tractor
[Re: Dodgem]
#1322995
10/20/12 12:13 PM
10/20/12 12:13 PM
MidPenMopar
Im using and have been using these Accell #8197 spark plugs that are a better fit when using headers that any others i have tried in the past. The engine starts on ome key turn and runs perfectly. So this coating of crud is what is me. Thought maybe it's the brand fuel i use but i only put in Chevron 91 as that's the best we get out here.
[Re: MidPenMopar]
#1322996
10/20/12 12:35 PM
10/20/12 12:35 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
It sure looks like oil to me most likely coming in from the bottom of the intake gaskets or the valve guides. Stu if you lived closer we could have the next Moparts party engine rebuild cookout Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1322997
10/20/12 12:48 PM
10/20/12 12:48 PM
MidPenMopar
Gus one of the things i have seen from the day i bought the car is a puddle of oil constantly in the valley of the manifold on the driver's side only though...Any thoughts on that?
