IDIOT: got paint thinner on my vinyl top
#1322730
10/19/12 08:07 AM
10/19/12 08:07 AM
Posts: 2,554 Maryland
wally426ci
Maryland
Ok, so I was cleaning up some marine caulk off of my rear glass after sealing the back window with the trim removed. During this, the rag soaked with paint thinner rubbed against parts of my vinyl top. I realized the effect it had and use rubbing alcohol to wash it away and then I hit it with a heavy dose of Armarol. Can anyone tell me if there is a product that can bring back the shine of the vinyl top in these areas? It dulled it but did not remove any of the grain.
Re: IDIOT: got paint thinner on my vinyl top
[Re: wally426ci]
#1322732
10/19/12 12:23 PM
10/19/12 12:23 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Maybe try some kind of Renue for leather and vinyl???
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: wally426ci]
#1322735
10/20/12 12:57 AM
10/20/12 12:57 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Do I need to tell you that you really screwed up bu putting the Armor All on it.. That stuff is a bunch of silicon. You will never get anything to fix it..
I am truckless..
[Re: wally426ci]
#1322736
10/20/12 02:36 AM
10/20/12 02:36 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
When I bought my Challenger, it had an insurance company claim number written on the sail panel of the vinyl top in yellow marking crayon. I left it alone but one over zealous idiot at the body shop figured that he'd wipe the number off with a rag and laquer thinner. Needless to say the top completely dulled in this area. After trying various products, I actually used some black shoe polish (the pastey stuff in the little can). Certainly not 100% revival, but at least it would shine adequately so it didn't stand out like a sore thumb. Lucky you didn't set the laquered rag down on the paint....you otta see what a nice "wrinkle" job that does....... DAMHIK
[Re: superwrench]
#1322737
10/20/12 02:26 PM
10/20/12 02:26 PM
wally426ci
Maryland
Ok, I went out this morning and hit the problem area around the rear windo heavily with 3 coats of the Bondo die. I then did the whole top twice with a light coat to blend it. It really looks fine right now but time will tell. I'll let it sit for the day and check it in the morning. Thank you for all of the feedback. To the silicone comment, they make chemicals to remove other chemicals so I prepped the roof before hand. On the negative side, wax and grease remover has a similar effect as paint thinner. Oh well. In another 5 years, I'll be hoping to pull the whole car apart and it will get a new top then.
[Re: wally426ci]
#1322738
10/20/12 03:51 PM
10/20/12 03:51 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I played around with a rip green v-top for my satellite years ago... sprayed on some sem black dye and it turned out really nice. If it was in better shape I would have left the top on as it looked good.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
