71 Demon - where's the wiper fuse? #132248
10/04/08 07:09 PM
10/04/08 07:09 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Of course the factory service manual doesn't list where it is, the closest the fusebox shows is "accessories", and there's nothing visible on the wiper motor itself.
Can anyone tell me where the fuse is? There has to be one...
TIA
Re: 71 Demon - where's the wiper fuse? [Re: sharpie] #132249
10/04/08 10:58 PM
10/04/08 10:58 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
It will be in the fuse box, usually if you take them out one at a time you can see which one is blown.
Re: 71 Demon - where's the wiper fuse? [Re: repad] #132250
10/05/08 10:46 AM
10/05/08 10:46 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
most if not all mopars don't have a fuse for the wipers- the wiper switch has a built in circuit breaker like the headlight switch- check to see if there is + 12 volts at the pink wire- if so- then your switch could be toast. check to see if the switch itself is properly grounded to the dash as well as the wiper motor has a good ground!!
John Mac
