66 Belvedere II Hemi #1321933
10/17/12 05:01 PM
10/17/12 05:01 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
on build sheet, what does "14Q" signify for the wheels? - i am clear that the 14 denotes 14" wheels, which is what they are - but how about the "Q?" - is that tells you that it is a 7.75x14 tire?
Re: 66 Belvedere II Hemi [Re: edl] #1321934
10/17/12 07:20 PM
10/17/12 07:20 PM
Usa
Smhemi Offline
Smhemi  Offline
Usa
Im guessing the car is red and the Q is for red painted rims.
Re: 66 Belvedere II Hemi [Re: Smhemi] #1321935
10/17/12 07:45 PM
10/17/12 07:45 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
One thing that will be certain about the wheels, they should be 14x5.5" rims (most other cars had 14x5.0's). You should see a 5 on either side of the valve stem hole which means 5.5. As mentioned, the Q is for the paint color.
Re: 66 Belvedere II Hemi [Re: Smhemi] #1321936
10/17/12 08:31 PM
10/17/12 08:31 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
car is red - as are the rims...so that lines up - thanks!
Re: 66 Belvedere II Hemi [Re: ScottSmith_Harms] #1321937
10/17/12 08:33 PM
10/17/12 08:33 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
Scott - great info - had no idea on the rim size - thank you for this!
