My 39' Dodge truck ratrod project #1321647
10/17/12 01:29 AM
10/17/12 01:29 AM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
I finally figured out how to get my pictures sized right to post them on here so I thought I would upload one plus give a description of the project.
39' Dodge cab
87' Dodge D50 frame
70' Mustang 8"
74' Mustang II crossmember
80's Dodge Omni rear steer rack and pinion
29' Dodge grill shell
30' Chrysler headlights
67' Barracuda /6 (out of my 67' Barracuda)
65' Mustang radiator
69' Plymouth A-body pedal assembley
48' Ford bedsides shortened 20"
Re: My 39' Dodge truck ratrod project [Re: GOT6PAK] #1321648
10/17/12 09:42 AM
10/17/12 09:42 AM
Endicott, NY, USA
crazyjjk Offline
crazyjjk  Offline
Endicott, NY, USA
Nice! Awesome that you used the slant 6 to power it.
Re: My 39' Dodge truck ratrod project [Re: crazyjjk] #1321649
10/17/12 11:05 AM
10/17/12 11:05 AM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
@ crazyjjk, thank you! The /6 looks right at home in there too. I'm building it to be my shop truck and to cruise to shows. It should ride real nice on the freeway. I made a custom mount and modified the alternator tension bracket so the alternator sits behind the grill shell on the drivers side. Kinda evened out the motor side to side.
Re: My 39' Dodge truck ratrod project [Re: GOT6PAK] #1321650
10/17/12 10:22 PM
10/17/12 10:22 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Looks like a fun project.
The rad shell looks funny with the big opening on the top. If it was mine, I'd probably either lower the rad shell, section it (take some out of the middle and bring the top and bottom closer together), or add a filler piece on the top, or any combo of each. Gene
Re: My 39' Dodge truck ratrod project [Re: poorboy] #1321651
10/17/12 11:39 PM
10/17/12 11:39 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
@ poorboy, the plan is to fill the area above the radiator. I'm still in the fabrication process and haven't got to that point yet. Good eye though.
Re: My 39' Dodge truck ratrod project [Re: GOT6PAK] #1321652
10/18/12 12:32 PM
10/18/12 12:32 PM
dogdays Offline
dogdays  Offline
Get out the 3/4" masking tape and string some lines from cowl to grille shell. That'll help you figure it out.
R.
Re: My 39' Dodge truck ratrod project [Re: GOT6PAK] #1321653
10/21/12 12:25 AM
10/21/12 12:25 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
What a nice project..
Re: My 39' Dodge truck ratrod project [Re: Webster] #1321654
10/21/12 03:42 PM
10/21/12 03:42 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
@ Webster, thank you! I'm really happy with how it's coming out.
Re: My 39' Dodge truck ratrod project [Re: GOT6PAK] #1321655
10/25/12 03:32 AM
10/25/12 03:32 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
subscribed
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: My 39' Dodge truck ratrod project [Re: fstfish66] #1321656
11/24/12 01:47 AM
11/24/12 01:47 AM
NE Ohio
mopar383 Offline
mopar383  Offline
NE Ohio
sweet
81 Dodge Ram My dad bought brand new... my 17 year old sons project
Jeep Wrangler Unlimited .....my wife's baby
Durango....my DD
Caravan...an awesome parts hauler
72 Dart
Re: My 39' Dodge truck ratrod project [Re: mopar383] #1321657
12/12/12 07:48 PM
12/12/12 07:48 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Cool..check out my 41 on here..somewhere
Re: My 39' Dodge truck ratrod project [Re: DusterKrazy] #1321658
12/15/12 12:59 PM
12/15/12 12:59 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Very cool project!
Update! I know it's been awhile lol... [Re: GOT6PAK] #1944004
11/02/15 11:11 PM
11/02/15 11:11 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
Finally got back to work on the 40' Dodge hotrod. Had a driveshaft made, cut floor and welded in driveshaft and trans tunnel along with floor. Welded in upper filler panel for radiator. Installed all new rear brakes and drums. Installed master cylinder. Installed shifter. Just ordered brake line kit with proportioning valve and residual valves so that's next. It already runs with my make shift wiring, so after brake lines are done I should be able to move it in and out of the garage. [img:center][/img]
Re: Update! I know it's been awhile lol... [Re: GOT6PAK] #1944008
11/02/15 11:17 PM
11/02/15 11:17 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
[img:center][/img]
Re: Update! I know it's been awhile lol... [Re: GOT6PAK] #1944010
11/02/15 11:17 PM
11/02/15 11:17 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
[img:center][/img]
Re: Update! I know it's been awhile lol... [Re: GOT6PAK] #1944011
11/02/15 11:19 PM
11/02/15 11:19 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
[img:center][/img]
Re: Update! I know it's been awhile lol... [Re: GOT6PAK] #1944014
11/02/15 11:21 PM
11/02/15 11:21 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
[img:center][/img]
Re: Update! I know it's been awhile lol... [Re: GOT6PAK] #1944017
11/02/15 11:23 PM
11/02/15 11:23 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
[img:center][/img]
Re: Update! I know it's been awhile lol... [Re: GOT6PAK] #1944021
11/02/15 11:27 PM
11/02/15 11:27 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
Also chopped the top 3 1/2" with the help of Ron Padsiadly. It looks so much more in proportion with the chop.
Re: Update! I know it's been awhile lol... [Re: GOT6PAK] #1953101
11/17/15 03:58 PM
11/17/15 03:58 PM
san diego
JonsGottaDusta Offline
san diego
That looks great, Pat!
