quartz clock #1321085
10/15/12 08:36 PM
10/15/12 08:36 PM
btomasko Offline OP
btomasko  Offline OP
The second hand moves,but the hands that tell the time do not,what would be a suitable fix for this problem? 62 plymouth thanks
Re: quartz clock [Re: btomasko] #1321086
10/15/12 09:52 PM
10/15/12 09:52 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
take the cover off the clock and and make sure the hand that is not moving is seated on the shaft. if you can, make sure the shaft is pressed into the gear. the gear would be in the back. if the gear isn't moving try a little wd-40 on it (just a small drop). sometimes dust can build up on the pin that holds the gear and stops the gear from moving.
