Page 2 of 6 1 2 3 4 5 6
Re: Keith Black Engines possibly closing the doors!!!! [Re: 40ford] #132092
10/05/08 01:35 PM
10/05/08 01:35 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
That is truly sad if it is true. Obviously, either what they are making isn't selling or can't make what is selling.
As a small businessman involved in manufacturing, there could be many reasons why this is happening---lack of profit, lack of sales, cost too high, the wrong location to manufacture(happens a lot today) or it could be something as simple as the family doesn't want to do it any longer!
I hope at least the name/product line can continue.
altho I will never have the oportunity to buy one, I hate to hear of another auto sport's Icon leave the bussiness, I hope that someone will step up and help pull this company back together before it's too late.
Re: Keith Black Engines possibly closing the doors!!!! [Re: dartman366] #132093
10/05/08 02:06 PM
10/05/08 02:06 PM
Anonymous OP
Anonymous OP
i bet indy and world are loving the news though'.
i hate to hear this again. it seems as though we are hearing this over and over again and we will hear this alot more in the near future.
Re: Keith Black Engines possibly closing the doors!!!! #132094
10/05/08 02:19 PM
10/05/08 02:19 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
they were making other type blocks..not just mopars..
I think they needed better marketing and reduced prices to get that company jump started..
when you see DART advertisements or BRODIX,they show their new blocks,heads,intakes and whatever else they have to offer..
whens the last time Keith black,outside of their piston line,actualy showed new items or had new items...seems the products they have just ran their course and not enough to keep their doors open...
whom ever buys out the company,hopfuly will offer new items with quality control of its namesake..
Re: Keith Black Engines possibly closing the doors!!!! [Re: smokinwoody] #132095
10/05/08 02:35 PM
10/05/08 02:35 PM
Anonymous OP
Anonymous OP
Sign of the times. You no worry, some Asian country make brock fo you.
Post deleted by Defbob [Re: Bob_Coomer] #132096
10/05/08 03:05 PM
10/05/08 03:05 PM
Anonymous OP
Anonymous OP
Re: Keith Black Engines possibly closing the doors!!!! #132097
10/05/08 05:56 PM
10/05/08 05:56 PM
Anonymous OP
Anonymous OP
that's really bad news. it'll be a shame to lose the only true Race block capable of handling "serious" horsepower.
does anyone else offer anything with comparable features?
you know what i mean,things that really matter, not just an aluminum base block.
Billit steel caps
finished lifter bores in the size and angle of your choice
1/2" head studs
double cross bolted center mains
standard or raised cam with choice of bearing size
unparalled customer service
it seems like everything else available is okay for the average N/A or "mild" boost combo (1000-1500hp) but lacks plenty for a serious (1500+)engine combo.
we have nobody to blame but ourselves.
Re: Keith Black Engines possibly closing the doors!!!! #132098
10/05/08 06:11 PM
10/05/08 06:11 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Billit steel caps
1/2" head studs
HP Performance Block
But I am disappointed to see Keith Black close. They made awesome parts and blocks. They're blocks were tried and true 2500hp capable blocks, even the street versions
Re: Keith Black Engines possibly closing the doors!!!! [Re: Defbob] #132099
10/05/08 06:17 PM
10/05/08 06:17 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Billit steel caps
1/2" head studs
The Koffel/Koleno blocks are stout pieces, as well.
This could be one reason they are going out of business, Dram, there are alot of block choices now. The World blocks and the Indy have probably cut into their business, as well.
Re: Keith Black Engines possibly closing the doors!!!! #132100
10/05/08 06:23 PM
10/05/08 06:23 PM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
Arias has been making a similar Mopar based Hemi block to the KB that includes short, regular, and tall water blocks with raised cam and a lot of other options.
website http://www.nickariasjr.com/forsale.html
Here is their description of the block:
" 426 Hemi Block "
Introducing the all new AA-500 Aluminum Block, a direct replacement fo your 426 Hemi. Many Fuel and Alcohol combinations can be manufactured.
• Revised, proven oiling systems.
• Outboard front/rear studs aid head stud retention.
• 1/2 inch or 9/16 inch head studs.
• Re-designed internal coring and ribbing dramatically
increases strength and stability.
• Standard or raised cam location.
• Short, standard or high deck water or solid.
• Short deck (.500) water blocks available.
• Four -bolt front main.
• "Y" block with four side bolts per cap.
PRI
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: Keith Black Engines possibly closing the doors!!!! [Re: Rapid588] #132101
10/05/08 06:35 PM
10/05/08 06:35 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
" 426 Hemi Block "
PRI
But there blocks have no cooling to the heads and missing three head bolts
Post deleted by Defbob [Re: Defbob] #132102
10/05/08 06:48 PM
10/05/08 06:48 PM
Anonymous OP
Anonymous OP
Re: Keith Black Engines possibly closing the doors!!!! #132103
10/05/08 07:12 PM
10/05/08 07:12 PM
Anonymous OP
Anonymous OP
what is the true cost and availability of the other blocks mentioned? also, what options do they have.
i know the world block is really just a glorified replacement block with limited options. pretty much the same for the Indy block.
Re: Keith Black Engines possibly closing the doors!!!! #132104
10/05/08 07:25 PM
10/05/08 07:25 PM
NY/NJ
DV8 Offline
mopar addict
DV8  Offline
mopar addict
NY/NJ
I agree 1000%!!! You never see any good used KB water blocks for sale compared to others who have been around way less than half the time...
Steve
"The function of man is to live, not exist..."
Re: Keith Black Engines possibly closing the doors!!!! #132105
10/05/08 07:42 PM
10/05/08 07:42 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
My block is currently only one of a few. and almost everything else is limited as well. I was hoping to beable to buy a KB block in the future when I build my next motor
The KB block was so versatile
Re: Keith Black Engines possibly closing the doors!!!! [Re: hemi_doug] #132106
10/05/08 07:46 PM
10/05/08 07:46 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
Sounds to me like the Bank pulled their credit line.....
You apparently have no idea as to what you are saying. The entire Black family are very close friends of my family, and I take offense to a flatout STUPID comment by someone that is just throwing out a comment, just to do it. Not cool at all. If you knew these people on a personal level, you would NEVER say or think of anything in a negative fashion, regarding the entire KB Racing company.
For those of you that are not into making comments like the one above, KB Racing has been for sale for quite some time, in a private, word of mouth fashion. With the hit on the economy, foundry prices going sky high, etc., etc., Ken has had to make some very difficult decisions. Let me tell you, this is killing him, as he has worked very hard over the years, to carry on the great tradition and products that his legendary father created. Very, very sad.
Re: Keith Black Engines possibly closing the doors!!!! [Re: B1CUDA] #132107
10/05/08 08:18 PM
10/05/08 08:18 PM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
I can just imagine this is hurting the entire KB family. Unless you have dealt with them, you have no idea just how customer oriented they are. The product and the customer service is second to none. Period.
I wish I had the funds to keep this business (KB) running just the way it is......I'd do it in heartbeat....and I have yet to meet ANYONE from this company face to face.
Karma has no menu. You get served what you deserve.
Re: Keith Black Engines possibly closing the doors!!!! #132108
10/05/08 10:09 PM
10/05/08 10:09 PM
AndyF Online content
AndyF  Online Content
I was getting ready to order up a low deck block for a new project. Hopefully Ken is still selling blocks.
Re: Keith Black Engines possibly closing the doors!!!! [Re: B1CUDA] #132109
10/05/08 10:58 PM
10/05/08 10:58 PM
California, USA
blairboy3 Offline
blairboy3  Offline
California, USA
Take it easy there B1Cuda... I don't think there was anything bad meant by his statement.
A lot of companies have lines of credit to help them through slow seasons. And a lot of banks have been pulling those lines of credit- not because of any wrong doing on the part of the account holder, but because the banks are afraid to let anymore bad credit affect their bottom line. I had one w/ Washington Mutual. When I started hearing about the problems WM was having, I pulled all the cash out of my line of credit. Sure enough... less than a week later WM had closed ALL lines of credit. Now, it's just a 15yr fixed rate loan on what I pulled out.
Anyways, whether or not that is the case w/ KB, it was a possible reason for why they couldn't keep things going.
1968 Plymouth Fury III 4-Door: 12.79 @ 115, 60'- 1.93 (Hey... it's a Cruise ship... what do you expect?!) Famoso Raceway, 02/08
Re: Keith Black Engines possibly closing the doors!!!! [Re: B1CUDA] #132110
10/05/08 11:23 PM
10/05/08 11:23 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i don't think that comment was meant as a hit toward KB, just an educated guess due to the fact that this is what the banks are doing now to many companies, regardless of their situation. if it's not the case then that's great, i would hate if KB didn't continue.
Re: Keith Black Engines possibly closing the doors!!!! #132111
10/06/08 12:29 AM
10/06/08 12:29 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
I think Hemi's and aluminum's are done or very soon ! http://www.b1heads.com/pdf/Koffels_block.pdf
