I took my 383 apart...what do you think?
#1320704
10/15/12 07:07 AM
10/15/12 07:07 AM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
I bought my 67 Charger with a 383 4bbl from 1971 in it. The engine is bored 0.030, has Eddy RPM intake and 750 Holley vacuum secs, Hooker headers. Compcams 21-224-4 grind XE274H is installed straight up. Intake closes @ 63 ABDC. Heads are 346 open chamber. I measured about 120 psi cold cranking pressure WOT. Now with the engine apart I see that the flat top pistons are 0.130 down the hole, calculate the static compression to 7.2:1, and the dynamic compression to 4.4:1. How do you think this engine was running?
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: I took my 383 apart...what do you think?
[Re: Oyvind Mopar]
#1320709
10/15/12 11:35 AM
10/15/12 11:35 AM
Swedcharger67
Norrland, Sweden
Like a stock Volvo, but more thirsty...
Öyvind, you get the Nobel prize! Your description gave me a good laugh, and it's very accurate!
Engine power is comparable to an ordinary Volvo, but consumes 3x more fuel!
This engine is a good example of how to NOT build an engine!
Martin
[Re: VincentVega]
#1320714
10/15/12 12:00 PM
10/15/12 12:00 PM
Swedcharger67
Norrland, Sweden
The 241 Red Ram started with 7.1:1. Obviously that's way too low for modern fuel and performance expectations.. but the good news is you could have put some boost on it, or run paint thinner in a pinch
Yes, you are right. I guess the 241 had a dyn compr ratio DCR not much lower than the 7:1, and that makes a difference. Even my engine would probably be pretty ok with a DCR of 7:1, even though I personally want to see it higher.
[Re: 65rbdodge]
#1320717
10/15/12 02:45 PM
10/15/12 02:45 PM
Posts: 1,647 IL
71383beep
IL
Been down this road before on the initial build for the 383 in the bee I used to have. Must have been rebuilt by the same knuckleheads except they billed me for a Comp Cams 268H and put it a POS cheapo cam from Elgin or something. During the second build they fond it to be at 7.8:1 when they opened it up.
Best thing I did was go to closed chamber 516 heads with a decent valve job and bigger valves. Ended up with 9.2:1 and that 383 became a beast. Compression is King!
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: dogdays]
#1320718
10/15/12 03:03 PM
10/15/12 03:03 PM
Swedcharger67
Norrland, Sweden
I agree on the piston rocking, that might have affected my measurement slightly. I have a spreadsheet where I just plug in all my data, and nothing helps on this engine with the pistons that far down. I plugged into the spreadsheet that I have Eddy Victor 75cc heads, and a Hughes Whiplash cam for low compression engines, and this cam even advanced 4 degrees...the static and dynamic compression is still a far cry from any acceptable numbers!
I attach a pic showing the numbers with Eddy Victor 75cc heads, Hughes Whiplash smog-cam advanced 4 degrees...
[Re: ireland383]
#1320720
10/16/12 11:04 AM
10/16/12 11:04 AM
Swedcharger67
Norrland, Sweden
Probably ok but no barn burner. What head gaskets were on there? What are your plans for this motor? You might want to run some KB400 pistons, steel shim gaskets, mill the heads some, and degree the cam. This will wake it up some.
I checked the numbers with KB400, quite a good choice, compression height 1.908, 6cc dome. With Victor 75cc heads it would give 10.4:1 static, and still allow for a bit of milling of the deck (0.027)...assuming the dome can fit there...
But, I have a 400-block ready for a stroker kit, so that's the path I'm going to follow...
[Re: Swedcharger67]
#1320721
10/16/12 11:30 AM
10/16/12 11:30 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
I personally think that KB400 is a poor choice , but with the limited choices for pistons I guess one takes what they can get.
Good that you have decided to go the 400 stroker route , those victors would be a bad choice to put on a stock stroke low compression 383 , you can cut your open chamber heads enough to get that 75cc number.
[Re: Swedcharger67]
#1320722
10/16/12 12:17 PM
10/16/12 12:17 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I have a 383 almost built the same. It was disapointing, weak low end power, decent power in the mid range, but nothing special, and not much top end. It was all done by 6,000 rpm. The 346 heads are correct for 1971. I think they were only used in '71, and maybe part of '72. A set of KB zero deck flat tops should help.
[Re: JohnRR]
#1320723
10/16/12 12:43 PM
10/16/12 12:43 PM
Swedcharger67
Norrland, Sweden
Yes, I used the Victors in my calculations just to see how small chambers would affect the compression...disappointing result with the pistons about 0.130 down.
