Power Brake Question #1320515
10/14/12 10:58 PM
10/14/12 10:58 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
How much vacumn does it take to operate power brake systems.
Re: Power Brake Question [Re: RBSat66] #1320516
10/15/12 09:41 AM
10/15/12 09:41 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I drove my GTX for years with 6.5 to 7 in gear. But you don't want to be absent mindedly pumping the brakes on the way to a stop or you pump off all your vacuum reserve.
I always keeped the idle up around 1100 in gear with a 263/271 @ .050 108 LSA cam.
Course you need a good booster and a good check valve.
