70 cuda fog lights are loose #1319916
10/13/12 10:03 PM
10/13/12 10:03 PM
Milwaukee WI
R_Blaha Offline OP
R_Blaha  Offline OP
Milwaukee WI
My fog lights or driving lights on my cuda are very loose or sloppy at the base where they bolt to the bracket making the fog light loose. Is there any way to tighten this up? Thanks
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT
1969 Dodge Superbee post coupe 383
1969 Dodge Superbee hardtop 472 hemi
1989 Mustang GT
1993 mustang lx 5.0
2004 screaming yellow cobra
2013 CVO Roadglide
Re: 70 cuda fog lights are loose [Re: R_Blaha] #1319917
10/14/12 10:30 AM
10/14/12 10:30 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
There is supposed to be a special, curved washer that goes between the roadlamp and the bracket - this helps with the adjustment.
If yours are missing or crushed flat, then the lamps won't really adjust or tighten up properly....
