Page 1 of 3 1 2 3
Stock appearing 425hp 383 possible? #1319622
10/13/12 11:48 AM
10/13/12 11:48 AM
Houston, Texas
Slant6pak Offline OP
Houston, Texas
Is it possible?
I'm planing on building a 383 for my 1971 Road Runner clone. I'm completely aware I could build a 440 for the same price and make more power... but I've always had a soft spot for 383s.
I'm starting fresh.... I don't even have a core engine yet. I only have 4 restrictions:
I don't want to stoke it.
An Air Grabber must fit, so I'm limited to a DP4B intake (which I already have)
Must run stock HP manifolds.
Valvetrain must fit under stock valvecovers.
Other than that I'm open to all suggestions.
Thanks in advance.
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: Stock appearing 425hp 383 possible? [Re: Slant6pak] #1319623
10/13/12 11:53 AM
10/13/12 11:53 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Very possible. I would go with a 400 block.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Stock appearing 425hp 383 possible? [Re: Slant6pak] #1319624
10/13/12 11:56 AM
10/13/12 11:56 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Ported 906 heads, 528 mopar mechanical cam, holley 750 and 10-1 compression (with your DB intake and HP manifolds). Should be pretty darn close.
2 kids and a dog
Re: Stock appearing 425hp 383 possible? [Re: Slant6pak] #1319625
10/13/12 12:45 PM
10/13/12 12:45 PM
gregsdart Offline
gregsdart  Offline
If you don't mind going with 915 (1967 440) heads, you can build the motor with quench and pick up some tq/hp to get close to your goal. Another option is KB hyper pistons with a quench dome and use 906 or 452 heads. But the KB / 906 combo may need machine work to get it right. Set piston to head at .040. For pistons, look for a 1/16 1/16 standard oil ring pack. A proper bore and hone with torque plates is the right way to go along with file to fit rings. Set clearances in the bearings for 10w30 weight oil. I would recommend Brad Penn. You will need to get in touch with a good engine builder to come up with where the clearances need to be for that oil. Probably about .0015 to .002 should work. Use a crank scraper or windage tray, and a 1/2 inch pickup and 6 quart pan.
Compression should be set at 9.5 to 1 unless you live at altitude. The 528 cam is a good choice, and the mechanical cam will allow the rpm needed to get to your goal. If you have a choice, go with 1.60 rockers. Some hydraulic combos won't rev well enough. I have seen one that laid over at 5600 rpm. Lastly if you run an automatic trans get a 9.5 converter set to allow some stall, at least 3000 rpm to match that cam.
Re: Stock appearing 425hp 383 possible? [Re: Slant6pak] #1319626
10/13/12 12:47 PM
10/13/12 12:47 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Its not that hard...
Does it have to run on pump gas?
-Id run a mechanical roller cam.
-400 block- Good machining techniques(square deck, torque plates, check main saddle bore integrity., etc) Get the lifter bores bushed/corrected.
-Some head porting-need not go nuts(heads are already prone to crack, once you port them then its even a more likely scenario).
-Most aftermarket rockers will clear the valve covers with some needing modification of the oil baffles(easy-just need some holes so the adjusters will clear).
-some good oil control.
-Get some quench dome pistons or domes if you want some more power and dont mind running some race gas.
Good Luck.
MB
Re: Stock appearing 425hp 383 possible? [Re: HPMike] #1319627
10/13/12 01:07 PM
10/13/12 01:07 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Why is stroking out of the question?
Mopar to the bone!!!
Re: Stock appearing 425hp 383 possible? [Re: 72Swinger] #1319628
10/13/12 01:25 PM
10/13/12 01:25 PM
Houston, Texas
Houston, Texas
My intake and exhaust manifolds are limiting factors... I don't want them choking the extra cubes. I'm also building a clone and starting with nothing... I could build a 440 if I wanted too, but I want the smaller displacement faster revving engine.
I hoping to fit the car with the one of the new Passon 5-speeds, with a 4.10 Sure Grip out back.
I'm also not opposed to aluminum heads vs. ported stock. I'm looking at "gasp" Stealth heads (I'm fully aware of their issues with valve locks) for no other reason other than that they appear fairly stock on the outside.
Re: Stock appearing 425hp 383 possible? [Re: Slant6pak] #1319629
10/13/12 01:40 PM
10/13/12 01:40 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
If you have no reservations about using aluminum heads then I strongly suggest you do. You'll get more power, more reliability for about the same amount of money(after you have a set of 906's ported and reworked with quality parts).
MB
Re: Stock appearing 425hp 383 possible? [Re: Slant6pak] #1319630
10/13/12 02:18 PM
10/13/12 02:18 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I would build a 400 , but if you you are stuck on a 383 then you can do that with flat tops and CLOSED chamber heads , buy the stealths , CNC'd would be the best choice that way they actually flow as claimed. build for no more than 10.5 compression , with alum heads , otherwise keep it at 10.0 max with closed chamber iron , 9.5 if you use open chamber heads , this will keep you pump gas friendly and make the power you want. I would use a flat tappet solid cam and ductile 1.5 rockers.
Andy F made over 550hp with stock iron manifolds , just pay attention to port mismatch with your heads so they aren't the cork you think for what you want to build.
Broken record time .... unless it's a CUSTOM PISTON ... no company makes a quench dome piston for a 383 ... no one ....
Re: Stock appearing 425hp 383 possible? [Re: JohnRR] #1319631
10/13/12 02:51 PM
10/13/12 02:51 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
An honest 425 horse on a legit dyno with a 10:1 383, exhaust manifolds, iron heads, and that intake is no easy feat...Not saying it can't be done, but it won't be like falling off a log.
MB
Re: Stock appearing 425hp 383 possible? [Re: HPMike] #1319632
10/13/12 03:04 PM
10/13/12 03:04 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
There's nothing about your parameters that would steer me away from building a 451. 440's make good power with stock manifolds, why not in a lowdeck block. Mine appears nearly stock and makes over 500hp. subtract headers and substitute a DP4B, and I'm right there in your wheelhouse.
I'd go with a solid flat tappet cam in 250 - 255 duration range; use a set of Eddy or source heads (if you're truly looking for the stock vibe), and an 850 holley up top, and I guarantee you'd be in the ballpark and be reasonably streetable. Getting an honest 450 horse out of a stock stroke 383 will mean a much more high strung motor that won't be as pleasant to drive.
Re: Stock appearing 425hp 383 possible? [Re: Slant6pak] #1319633
10/13/12 03:12 PM
10/13/12 03:12 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The more cu. in., the better. Why? You can put a bigger cam in while retaining a stock like idle. Unless you are under budget constraints, it would be silly to use a stock stroke 383 if you are looking to maximize power. Here is an option:
451 cu.in
Ported Stealth's
10.5:1 CR
Custom ground cam
Divider removed from DP4B
2 1/2" TTI and Ultra Flows
Easy 450 hp with a hydraulic cam, and never open the hood again. Or 500 hp with an agressive cam. All on pump gas.
Re: Stock appearing 425hp 383 possible? [Re: Slant6pak] #1319634
10/13/12 03:14 PM
10/13/12 03:14 PM
In my opinion you are looking at the stroke wrong, the stock exhaust manifolds and intake limit the peak torrque and HP RPM,I would at least think of using a 440 crank on your build That makes it act like a 426W Or better yet a 440 crank offset ground to 3.91 stroke and use the BB Chevy rod journal size and cheaper good quality H bem steel rods The 400 block with either the 440 crank or the offset stroke 3.91 crank will make a really good combination for what your doing I've made 500+ HP with a pump gas 440 based stock stroke motor with iron heads a bunch of times, add a set of aluminum heads and 540 HP gets in sight very easily Good luck on your build, it is very smart to think of what to do and use before starting
Re: Stock appearing 425hp 383 possible? [Re: HPMike] #1319635
10/13/12 03:24 PM
10/13/12 03:24 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Don't write off a stroker just because you want to keep your manifolds. Just need to pick the right cam for the application. Displacement is your friend.
I would do the 400 stroked to 496. CNC Stealths with dished flat tops zero decked for 9:1. With a cam ground with HP manifolds in mind (see Dwayne Porter or AndyF) you should knock hard on 500hp/600ft/lbs and be all done by 5000 RPM. Nice street engine and only needs 87 regular gas to boot.
Kevin
Re: Stock appearing 425hp 383 possible? [Re: Twostick] #1319636
10/13/12 03:47 PM
10/13/12 03:47 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
425HP is not at all difficult with stock manifolds, though I'd port-match them just because I can't leave anything alone or pass up "free" power. You don't need a Holley or headers to hit your target; I've done it.
What's your budget for the motor? Do you want it to have nice street manners and/or relatively smooth idle?
The stroker deal will be less peaky at the same power level, since as a street motor what matters most is torque; if you need to buy all the parts anyway, it's a slam dunk. I'd go with the Stealths, with upgraded hardware and attention paid to the valve job & chasing threads. If you want to run 13/16-hex plugs, you need to open up the area where your plug socket interferes with the casting.
Re: Stock appearing 425hp 383 possible? [Re: topside] #1319637
10/13/12 03:56 PM
10/13/12 03:56 PM
Central NC
gch Offline
gch  Offline
Central NC
No matter what you decide the power you want lies in the head/headwork.With a set of good flowing heads you can easily hit that goal with a 383.
Any larger displacement will only make it easier.
Re: Stock appearing 425hp 383 possible? [Re: gch] #1319638
10/14/12 09:06 AM
10/14/12 09:06 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
What kind of Hp are the FAST guys making with manifolds?
I also don't see any reason to NOT use a stroker. Total Hp may be the same, but with a stroker, you'll get that Hp at a much lower RPM and will be easier on the parts inside the engine
**Photobucket sucks**
Re: Stock appearing 425hp 383 possible? [Re: 70Cuda383] #1319639
10/14/12 09:23 AM
10/14/12 09:23 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
I agree.
3.75-3.91 stroke won't hurt the budget and won't cause extreme stresses on the bottom end.
Plus the final displacements with either of those will be near enough to 440CI, which is what the stock heads were designed for.
Going to 484 or 500CI IMHO is a whole different ballgame....
Re: Stock appearing 425hp 383 possible? [Re: 70Cuda383] #1319640
10/14/12 09:51 AM
10/14/12 09:51 AM
ny
greenmcode Offline
greenmcode  Offline
ny
I run a stock stroke 440-6 in my A12 runner...The reason i went
that rout than a stroker is the car is a real m code and wanted
to keep the originality of the car...I was asked why, Its cheaper
to buy a stroker kit and so on.. As for the H.P. it was never
dyno, The car is 3920 11.65 at 117.60 175 60' on bias..
12 to 1 comp.
hyd flat tappet..
I would build what you want.. Can you get 425 hp out of a stock
stroke 383? I would think so..
1969 A12 R.R. 11.61 117.96 F.A.S.T. STOCK STROKE..
Re: Stock appearing 425hp 383 possible? [Re: greenmcode] #1319641
10/14/12 11:27 AM
10/14/12 11:27 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
12 to 1 comp.
Your car is making about 516hp....Question is, how much does a motor like that cost???
If you can't handle the truth, you're living a lie.......
Page 1 of 3 1 2 3
