361 blocks how much power can they take? #1319580
10/13/12 08:19 AM
10/13/12 08:19 AM
SW WI
cudacustoms1 Offline OP
SW WI
I have been looking into a class that runs a 377ci limit. You can run 8-71 blower 10% over or turbo. Just trying to think of the cheapest way to make power with a mopar. My question is has anyone pushed a 361 block. Are block any different from 383/400/440? How much power do you think they will hold? The hp numbers I have heard in this class is 1000-1100. Any input would be great. Thanks
Re: 361 blocks how much power can they take? [Re: cudacustoms1] #1319581
10/13/12 02:28 PM
10/13/12 02:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would find a thick web 400 block and have it sleeved down to the bore size you need to be at 377.
Re: 361 blocks how much power can they take? [Re: JohnRR] #1319582
10/13/12 03:27 PM
10/13/12 03:27 PM
Better yet reduce the stroke to make the C.I., not the bore
Re: 361 blocks how much power can they take? [Re: Cab_Burge] #1319583
10/13/12 03:32 PM
10/13/12 03:32 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
A 4.375 bore and a 3.125 stroke gives u 376 cu in. If u went with a 2.2 rod journal u should be able to offset grind it to 3.125". Will it be purely race or a street motor as well?
Although, sleeving it down will give u some extra meat in the cyl walls, but destroking it and running longer rods will be easier on the bottom end and stave off cap walk a little better, which seems to be the death of these engines, just some things to ponder
Re: 361 blocks how much power can they take? [Re: Cab_Burge] #1319584
10/13/12 03:48 PM
10/13/12 03:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would de-stroke a 400 block, specially since your
talking pressurizing it
Re: 361 blocks how much power can they take? [Re: MR_P_BODY] #1319585
10/13/12 04:07 PM
10/13/12 04:07 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
If u went with a 4.375 bore, a 3.125 stroke, 7.1 rods, u would need a piston with a compression height of 1.3175" for zero deck, where a 1.32CH piston is a readily available piston for BB Mopars so this combo would work, well on paper anyway. U would have a rod/stroke ratio of 2.272 which would help your bottom end survive. I would go this direction if I were you
Re: 361 blocks how much power can they take? [Re: WO23Coronet] #1319586
10/13/12 07:02 PM
10/13/12 07:02 PM
SW WI
SW WI
What uses the 3.125 stroke that you are talking about? If you are talking a custom crank then I guess you missed the part about on the cheap.I like the 400 idea. Big boar /short stroke. A block you can find and not break the bank.The idea of sleaving all the holes would get pricey in a hurry.Plus I would like to keep the bore big to fit as big of valves as possible. It would be full race on alky.
Re: 361 blocks how much power can they take? [Re: cudacustoms1] #1319587
10/13/12 08:03 PM
10/13/12 08:03 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
You missed the part where you offset grind a stock 361 or 383 steel crank to get 3.125. This really sounds like a good build idea to me.
Sheldon
Re: 361 blocks how much power can they take? [Re: RUNCHARGER] #1319588
10/13/12 09:33 PM
10/13/12 09:33 PM
SW WI
SW WI
Thanks I did miss that. Has any one heard what kind of HP a 400 block and offset ground crank could handle?
Re: 361 blocks how much power can they take? [Re: cudacustoms1] #1319589
10/13/12 11:34 PM
10/13/12 11:34 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
The only way to keep the big bore is with an offset ground crank and I guess I didn't specify I meant an offset 383 forged crank, which are about as cheap as they come. From what guys say on here a 400 block is good til 6-700 ish hp NA and that's usually using a stroker crank which is harder on the bottom end. But if u girdle it, give it a tall fill of hard block (race only engine on alky), use a turbo (supposed to be easier on a block than a supercharger) and since u would have a ridiculously good rod ratio because of the short stroke, it might live at the 1000-1000 hp mark. U could also run aluminum rods since this helps the bottom end survive better as well, but I know u are on the cheap so things could add up pretty quick. I think it would make a sweet combo and have a good chance of living
On a side note, are 361 industrial blocks any better than a standard 361?
Re: 361 blocks how much power can they take? [Re: MR_P_BODY] #1319590
10/14/12 08:12 AM
10/14/12 08:12 AM
gregsdart Offline
gregsdart  Offline
I would first do some research on how much cylinder wall thickness is going to be needed to keep things sealed up at boost. Then see if rings are available for the biggest big bore to short stroke combo I could put together. Its gotta seal first, then go with a big bore for airflow around the intake valves. What heads can you run? What fuel? I take it this is a drag racing class?
Re: 361 blocks how much power can they take? [Re: gregsdart] #1319591
10/14/12 08:33 AM
10/14/12 08:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My next question would be what is the track length for
the races 1/4 or 1/8... the blower cars tend to be
quicker in the 1/8 but the turbo cars are in the 1/4
Re: 361 blocks how much power can they take? [Re: MR_P_BODY] #1319592
10/14/12 05:28 PM
10/14/12 05:28 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What is the bigger issue with a 400 block for longevity? Cylinder bore thickness or cap walk? Thick cylinder bores are good I'm not questioning that at all but LS and Gen III Hemis have pretty thin bores from the factory and they survive pretty well at the 1000 hp mark, but they are way more robust than a 400 in the bottom end dept, which I think would be the 400's bigger issue.
Speaking of which, why don't u go with a Gen III Hemi? 5.7's are dirt cheap, put in a 6.1 forged crank(cheap on EBay), some good Eagle heads and a turbo, 1000 hp + no sweat. If u don't want FI put a carb on and get the MSD Hemi 6 for the ignition.
