Small Block accessory Options??? for W9 heads. #1319576
10/13/12 07:30 AM
10/13/12 07:30 AM
Texas Afghanistan Iraq etc.
DakFink Offline OP
DakFink  Offline OP
Looking for what options I have to keep my Power steering from a Magnum Style accessory set-up.
Here's my dilemma. My Magnum (5.9L) Engine crapped out and needs to be rebuilt or replaced.
I just so happen to have a set of W9's and an Intake BIB. They were slated for another project but their spot got filled.
I would like to build an R3 with one of BME's 4.25" stroker cranks and use these heads and keep it around 10.5:1 (street engine)
Only issue I have is where to mount the Power-steering and Idler-tension-Pulley from a Magnum Style setup. W9's don't have the accessory Mounting holes that regular (LA/Magnum) heads have.
I want to put it in a street truck.
I already have a complete Drag Truck in the works.
Re: Small Block accessory Options??? for W9 heads. [Re: DakFink] #1319577
10/13/12 10:36 AM
10/13/12 10:36 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
r3 block doesn't have any holes either. u could use a motor plate & make up ur own mounting system or go with rack & pinion steering.
Re: Small Block accessory Options??? for W9 heads. [Re: DakFink] #1319578
10/13/12 10:58 AM
10/13/12 10:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you run a motor plate you can mount the steering
bracket on the frame rail... if you do the frame bracket
right you can have the tensioner part of it but I
dont run the tensioner with a motor plate
Re: Small Block accessory Options??? for W9 heads. [Re: MR_P_BODY] #1319579
10/13/12 03:23 PM
10/13/12 03:23 PM
DakFink Offline OP
DakFink  Offline OP
Magnum style accessories don't mount directly to the block. They mount to a bracket that bolts on top of / around the timing housing. As long as you have the timing cover holes all other accessories can be mounted.
It's the power steering mainly That I have an issue.
I believe I could do away with or relocate the tensioner and get a different size belt to accommodate.
I really don't want to use a plate as this will be going in a street truck that ha motor mounts that will work with an R3 Block.
