Re: 340 bent valve and still have good compression?
[Re: W5Duster436]
#131952
10/04/08 11:52 AM
10/04/08 11:52 AM
RapidRobert
take the hose from your compression tester & pipe some air in from your shop air compressor to each cyl(at tdc) & see if it's coming out the tailpipe(s) or carb or radiator.
[Re: RapidRobert]
#131953
10/04/08 12:05 PM
10/04/08 12:05 PM
Posts: 4,084 Indiana
W5Duster436
Indiana
Would do if I had a compressor.
Hence needing to take it and have a complete leakdown done.
[Re: W5Duster436]
#131954
10/04/08 02:24 PM
10/04/08 02:24 PM
bent valve? dont run it. sooner or later you'll lose a seat, have it bind up and destroy the valve guide, roast the moter
[Re: W5Duster436]
#131958
10/04/08 02:46 PM
10/04/08 02:46 PM
Posts: 1,032 santa rosa,ca
RTDude
santa rosa,ca
Maybe a weak/broken valve spring?
[Re: RTDude]
#131959
10/04/08 03:33 PM
10/04/08 03:33 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Much more likely that this is the problem, than a bent valve.
The heavy part of the spring is likely broken, and only the dampener is remaining. IT's enough to close the valve on a copmp test, but it bounces while running, giving you your issue
