need informaiton on big block A-bodies
#1319350
10/12/12 08:40 AM
10/12/12 08:40 AM
Posts: 1,175 Woodbridge
Tommy The Chryco
Woodbridge
does anyone know the type of 4 speed transmission used in these big block cars from 67-69? where the same as B-bodies? was there a particular part#
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: need informaiton on big block A-bodies
[Re: Tommy The Chryco]
#1319351
10/12/12 11:05 AM
10/12/12 11:05 AM
Posts: 43,540 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
They are 23 spline A833 4-speeds made by the New Process company. They are the pretty much the same as B-Body transmissions except for the tailshaft and output shaft lengths. There were two part numbers, the 67-68 is 2892042 and the 69 is 3410608, I do not know the differences. BTW, these part numbers are the same for 273, 318, 340 and 383 trans. The 67 273 had it's own part number.
JB Rhinehart, Realist
A-Body's RULE!
#1319352
10/12/12 11:18 AM
10/12/12 11:18 AM
Posts: 1,187 USA
big-block-dave
USA
From white book '67 273.......................Part#2538399...Build sheet code 395 '67-'68 318, 340, 383....Part#2892042.........................041 '69 273, 318, 340, 383..Part#3410608..........................602
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
