rack and pinions
#131917
10/04/08 10:24 AM
10/04/08 10:24 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Gentlemen and Ladies,
I am pondering a remake of my steering. I wonder if anyone has a link to rack and pinion dimensions? I want to rewoek my steering to allow more header clearance and need to see if there is anything out there that would work.
Thanks in advance.
Re: rack and pinions
[Re: poorboy]
#131919
10/05/08 09:48 AM
10/05/08 09:48 AM
Supercuda
About to go away
About to go away
up yours
Well, what I wanted was lengths, not diameters. Basically what I want to do is put a rear steer rack in place of the manual box in my 65 Cuda. So I need a rack that has the inner tierod pivots about the same distance apart as the original idler/pitman pivots. I'd prefer manual steering anyway, not interested in power, don't have it now anyway.
I'll also need to find outer tierods that'll have the same diameter and taper as the stock tierods since I need to attach them to the steering arms. I used to have a TRW Chassis spec book that detailed this kind of thing, but it's about 15 years old and who knows where it is now, probably in the attic somewhere.
But if there was a PDF on the web somewhere that I could look over I'd be happy. That's what I did when I needed new shocks for a suspension drop I did on a Mustang.
[Re: Twostick]
#131921
10/26/08 02:44 PM
10/26/08 02:44 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
That Just Suspension kit is a repackaged Unisteer which has gotten poor reviews on this board.
[Re: poorboy]
#131923
10/29/08 07:31 PM
10/29/08 07:31 PM
Supercuda
About to go away
About to go away
up yours
Is the Cavalier a rear steer?
If not then I'll have to pass on it. Not real interested in compeletely redoing the front suspension design.
[Re: moparx]
#131927
10/30/08 08:50 PM
10/30/08 08:50 PM
Posts: 10,555 Freeport IL USA
poorboy
Freeport IL USA
On my Plymouth, the center pivots (attached directly to the rack) were 2" apart at the center (I only had a right and left tie rod assembly with no center link) and went all the way to the steering arm at the spindles. I no longer have the car, but we did drive it about 6,000 miles. Didn't notice any bump steer unless you were doing a sharp turn at low speeds, then you could notice a bit of bump steer. Also, I still had the shocks at factory instalation, which was between the upper and lower control arms. Was intending on moving the upper mount but sold the car first.
There are 2 other minor inconvences you should know about. 1) the car did not turn as sharply as it did originally, I suspect the turning radious was probably 5' larger diamiter then original. 2) at highway speed, 70-75mph, the steering was a bit touchy (I had power steering) What would be a minor in-lane correction at 30 mph would be a 1/2 lane correction at 75. I suspect a pressure regulater on the pump would have solved that problem. (Another thing that was on my list I never got to.)
The picture above your post shows how the rack and tie rods compaired the original box and tie rods as layed out in the car. I used the Cavalier rack (Intrepid is a front steer rack) with the Intrepid tie rods which I shortened to match the length of the original in overall length. Gene
[Re: moparx]
#131929
11/04/08 03:12 AM
11/04/08 03:12 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
i have a mustang rack rear steer manual,on my 66 cuda,,modified factory k member,
caviler rack rear steer on my 1940 dodge,its a fat man fab kit,works great,.i had hdy high pressure problems,,sent the GM, mini remote pump to unisteer they put a lower flow valve in it ,and its nice now,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#131930
11/05/08 10:27 PM
11/05/08 10:27 PM
Supercuda
About to go away
About to go away
up yours
What year is that Stang rack?
I had a 96 Stang and it's a front steer unit. I can;t remember what the fox body ones are, been many years since I messed with a fox body stang. Thanks
[Re: Supercuda]
#131931
04/07/09 02:25 AM
04/07/09 02:25 AM
fstfish66
levittown pa
the rack is from an early pinto / mustang style,the most popular rack conversion,,
sorrythe reply took sooo loong,i do not get e mails from this site about topics answered,,i was just reading old topics,killing time
[Re: fstfish66]
#131932
04/08/09 02:54 PM
04/08/09 02:54 PM
John_Kunkel
Rio Linda, CA
Those who are contemplating a front rack installation should study up on The Ackerman Effect.
[Re: John_Kunkel]
#131933
04/08/09 10:21 PM
04/08/09 10:21 PM
Supercuda
About to go away
About to go away
up yours
I don't think anyone said anything about front steer, I know I specifically asked for a rear steer setup.
[Re: Supercuda]
#131934
04/08/09 11:24 PM
04/08/09 11:24 PM
poorboy
Freeport IL USA
John, we did not modify the existing outer tie rod location, we only exchanged the type of steering used from a box to a rack.
Were I to do a rack install again, I would make a center link that bolts the the Caviler rack and would use the vehicals original tie rods complete. I believe that would make life a lot easier. The center connection of the Caviler rack has 2 bolts about 2" apart. Make a link that uses both center bolts and extends outward on both sides to where the original cars inner tie rods would connect. Problem solved. Gene
[Re: Supercuda]
#131935
04/09/09 04:00 PM
04/09/09 04:00 PM
John_Kunkel
Rio Linda, CA
The comment directly above mine referred to an early Pinto/Mustang rack which is a front steer.
Some here are referring to rear-mounted racks with the tie rods at the front as "front steer", my comment about Ackerman was about racks that mount in front of the kingpin.
I would refer to the Cavalier as a "rear-mount center steer", a simple "L" bracket can change front-mounted tie rods to the rear and vice versa.
Here's a Cavalier installation I recently completed on a Brand X.
[Re: John_Kunkel]
#131936
04/09/09 06:18 PM
04/09/09 06:18 PM
Supercuda
About to go away
About to go away
up yours
Ah, my mistake. Like I posted above i don't want a front steer rack setup. Too much rework needed to make it happen.
The Cavalier rack looks promising, but stock I gotta think bump steer is an issue?
I suppose a "centerlink" bolted to the rack could be made and that would limit bump steer.
