68 vs 69 coronet hoods
#1319157
10/11/12 09:09 PM
10/11/12 09:09 PM
Posts: 1,992 midwest
68427vette
midwest
is there a difference,, i want to make an extra 69 N96 hood, but have found a few local 68 hoods around, will a 68 fit, look right,, not too worried about underneith bracing looks, thanks jc
Re: 68 vs 69 coronet hoods
[Re: 68427vette]
#1319158
10/11/12 09:24 PM
10/11/12 09:24 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Just the 'filler' piece under the front leading edge that matches the contour of the grill.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: OhioMopar]
#1319159
10/12/12 10:40 AM
10/12/12 10:40 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
same hood except for the filler piece screw holes not drilled ... though you may find a LATE 68 hood that is in prep for the 69 model year ??? ... the underhood bracing SHOULD be the same
[Re: MO_PA]
#1319161
10/12/12 11:35 AM
10/12/12 11:35 AM
JohnRR
U.S.S.A.
Under hood bracing is different...how do I know? I bought a hood pad for a 68 and it did not match the 69 hood on my 68 Coronet R/T
Was it just hole placement for the clips or is it completely different ? The biggest concern for the junk collector is putting the ductwork in place .
[Re: MO_PA]
#1319162
10/12/12 01:01 PM
10/12/12 01:01 PM
68427vette
midwest
as long as its visually the same from the top, the 68 will work on a 69, after i cut holes for the two scoops... then right? just different pad and spacer piece then correct,
[Re: 68427vette]
#1319164
10/12/12 03:11 PM
10/12/12 03:11 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Are you just putting the scoops on the top and not the underhood assembly?
If yes, then that's not really N96. It's a hood with decorative unfunctional scoops.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#1319165
10/12/12 04:45 PM
10/12/12 04:45 PM
68427vette
midwest
yes i know what a N96 is, my 69 coronet RT has it and my 70 SB 440/6 has them, just want to know if 68 hood will LOOK the part, but good question,, will a 68 hood ACCEPT the 69 N96 goodies under the hood?? or are the bracing in the wrong spots to accept the ram air set up.. i'd think the scoops on top would or could be drilled anywhere. and YES be decorative unfunctional scoops.. and not truly a N96 set up. jc
[Re: 68427vette]
#1319166
10/12/12 06:43 PM
10/12/12 06:43 PM
JohnRR
U.S.S.A.
then don't cut the holes ...
[Re: JohnRR]
#1319167
10/12/12 10:07 PM
10/12/12 10:07 PM
Posts: 2,230 restos just aren't my thing
gtsuperbee
69 duct work doesn't fit a 68 hood on a bee or a chicken
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
[Re: gtsuperbee]
#1319168
10/13/12 09:43 AM
10/13/12 09:43 AM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
So , i have a 69 hood , i havent looked , but , it WOULD Have the provisions for uhood duct . And can be converted ?
